coolant low warning
Old Oct 28, 2018 | 01:04 PM
ribbyp18's Avatar
Default coolant low warning
I have a 2006 XJ8 that's showing a coolant level low warning even though the expansion tank is full, just like some others have posted. I have taken out the tank and cleaned it out and the float seems to move about freely. I also saw a tip somewhere else that said that too much water in the coolant could keep the float from floating. After removal, cleaning, replacement, and refilling coolant to level, the warning was gone...until about 15 minutes later. Could this be the sensor that needs replacement or the tank due to a possibly faulty float?
Old Oct 28, 2018 | 04:04 PM
34by151's Avatar
Check the wiring harness plug, located in the inner guard for corrosion.
Also check your earth point
34by151
Old Oct 30, 2018 | 01:36 PM
annamiata's Avatar
Expansion tank with sensor is cheap. Replace it. https://www.ebay.com/itm/NEW-Overflo...CMake%3AJaguar
Both S-type and XJ8 use the same expansion tank.
Old Oct 31, 2018 | 06:21 PM
ribbyp18's Avatar
Done it twice since I've had the car, just hoping it was something else.
Old Oct 31, 2018 | 06:25 PM
ribbyp18's Avatar
annamiata, done it twice since I've had the car(cracked nipple), was hoping it was something else simpler, less costly.
Old Nov 2, 2018 | 03:45 PM
annamiata's Avatar
Do you still have the two old damaged expansion tanks. The sensor can be remove and replace with one twist. I keep junks like various sensors when I visited junk yard or have old parts lying around in garage.
Also, you should on the heater at full blast when change coolant. This will circulate more coolant into the system due to air void. I had the same issue with sensor low coolant and had to bleed coolant several times to completely fill the system with coolant.
Old Nov 7, 2018 | 03:22 PM
ribbyp18's Avatar
Thanks for all the advice. Tried all of the above, everything looks good, but still have the coolant low warning on. I also disconnected the sensor thinking that if basically there's "no sensor" due to it being disconnected, then how can it detect low coolant and send a message to put out the low coolant warning. It still came on. Any more thoughts?
Old Nov 7, 2018 | 03:26 PM
ribbyp18's Avatar
By the way, annamiata, the first tank was gone years ago and I just tossed out the second one a couple months ago while cleaning the garage. Didn't think to keep the sensors. Damn! But appreciate the tip.
Old Nov 7, 2018 | 11:56 PM
toyman1001's Avatar
Loss of sensor input is probably the safe default mode displayed as "Low Coolant".
Old Nov 18, 2018 | 03:56 PM
ribbyp18's Avatar
Another observation is that I can always remember that the coolant level was always correct when nothing was going wrong, but now, whether the car's been running or not, it's to the top of the expansion tank on the left side even if there's little to none in the right side. Thanks for all of the tips, but nothing has worked so far. Hoping maybe replacing the expansion tank will fix it.
Old Nov 18, 2018 | 06:04 PM
meirion1's Avatar
"it's to the top of the expansion tank on the left side even if there's little to none in the right side. "
It does sound like a new tank will fix it IMO
Old Nov 25, 2018 | 12:00 PM
ribbyp18's Avatar
Thanks meirion
dmukic
Oct 26, 2019 10:49 AM
tiouis1964
May 9, 2019 04:12 AM
blackjaguarxk8
Jul 7, 2018 01:31 AM
svldvc
Feb 12, 2011 01:46 AM
warekito
Aug 9, 2007 10:02 AM
