crank case vent tube where does it connect?
Old 02-20-2018, 07:49 PM
BadCat1's Avatar
Default crank case vent tube where does it connect?
04 XJR I think it's the long brittle plastic tube that connects to the pcv valve? The round thing on the left top of valve cover. I had the Charger off, got everything else back together but can not figure our where that connects, plus it broke so wondering if maybe some heater hose would be a better option? Thanks all this has been a HUGE project so looking forward to firing her up soon!
Old 02-20-2018, 07:58 PM
jackra_1's Avatar
Received 1,755 Likes on 1,326 Posts
This pic shows where it connects to the elbow under the throttle body.
Took loads of pics when I first disassembled everything.
Attached Thumbnails crank case vent tube where does it connect?-2016-04-19-09.30.19.jpg
Don B (02-20-2018)
Old 02-20-2018, 10:41 PM
BadCat1's Avatar
Thanks again Jackra it looks like it wrapped underneath from the passenger side and should have been attached before everything else went back on. I have everything back together so looks like this may be fun to try and attach way up in there ugh so close yet so far..
Old 02-21-2018, 08:08 AM
jackra_1's Avatar
Some pics that might help. I do have an oil catch can at the PCV end of the tube in question.
It runs just under where the driver side charge cooler connects to the "spreader" inlet. It goes all the way back and curves around and under to where it joins the elbow.
Attached Thumbnails crank case vent tube where does it connect?-p1000103.jpg   crank case vent tube where does it connect?-p1000102.jpg   crank case vent tube where does it connect?-p1000101.jpg   crank case vent tube where does it connect?-p1000100.jpg
Old 02-21-2018, 08:22 AM
Box's Avatar
Box
Box is offline
Heater hose is not impervious to vapor, so you would not want to use a heater hose. There is specific hose for use with vapor.
Old 02-21-2018, 04:39 PM
Wooford XJR's Avatar
I am also have the oil issue in the intercoolers and want to install a oil catch can. Does anybody have a source for plastic fittings that connect the hose at the Supercharger elbo or PCV valve?
Thanks in advance Woodford XJR
Old 02-21-2018, 05:30 PM
jackra_1's Avatar
Thats a good question.
I had no luck at all when I searched for something and ended up with a bit of a kluged connection. However it works.
I actually used my old, but good, valley hose for part of the solution.
If I could use something more appropriate I would.
Attached Thumbnails crank case vent tube where does it connect?-p1000104.jpg
hlgeorge
04-17-2015 10:33 AM
Jon89
31
04-07-2015 07:45 AM
stevedask
02-23-2015 07:08 AM
MooSSe
01-09-2013 10:13 PM
rogerdodger
09-04-2012 07:14 PM
Quick Reply: crank case vent tube where does it connect?
