Door lock problem
Old Sep 4, 2023 | 08:23 PM
Boomer from Boston's Avatar
Default Door lock problem
My 2006 XJ8L has developed a problem with the left front door lock. It will not lock or unlock using the fob. I can lock or unlock using the manual lever inside. If I lock or unlock it manually, the fob will not change its status. The other 3 doors work as they should.
I am presuming that either the electric solenoid actuator in that door has burned out, or else the linkage from the actuator has become stuck, perhaps from corrosion. Is this hard to trouble-shoot? Is it difficult to get the door interior trim panel off? Any advice appreciated. Thanks !
Old Sep 4, 2023 | 08:24 PM
Oops !! I meant the RIGHT (passenger) door lock.
Old Sep 6, 2023 | 04:58 PM
meirion1's Avatar
You need to take the door card off and have a look.
It's possible the cable is very tight since it locks then unlocks immediately.
Hidden screws are one behind chrome handle and one that screws upwards
below bottom door storage compartment.
If there is nothing obvious maybe clean pins on DDM in driver's door
in case pass. door lock not getting signal from fob.
Search this forum for details and pics re card removal.
BTW disconnect battery first.
Boomer from Britain lol
Old Sep 8, 2023 | 12:09 PM
The other day I tried the locks and the misbehaving one actually worked, but only briefly.. I cycled it a few times and then it quit working, and hasn't worked since. I am just getting myself psyched up for the task of taking the door panel (card) off.
Old Sep 9, 2023 | 05:09 PM
meirion1's Avatar
Possible failing microswitch in the actuator.
raid4381
Apr 10, 2023 12:30 PM
Dwayne Mason
Aug 22, 2022 12:33 PM
nsboxing
Jan 31, 2017 04:07 PM
AW2Jaguar
Jul 23, 2013 12:05 PM
