Drivers seat won't lower rear portion.
Old Jan 29, 2023 | 05:13 PM
davidlieb's Avatar
Default Drivers seat won't lower rear portion.
Hi Folks,
My drivers seat that won't lower its rear portion in my 2004 XJR. The motor kind of twists weakly, clunks, and then stops.
I detached the seat and used silicon spray to lube the screw that the rear motor is trying to turn. The spray didn't make a difference. |
I'm not sure what I should replace or where to order the parts. I'm guessing I'll replace the motor or the whole up/down assembly, but any advice is appreciated.
Old Jan 30, 2023 | 08:05 AM
Wingrider's Avatar
Just a guess, but often replacing the brushes will fix things.
Take the motor out, open it, to see if they are worn down.
If theres an automotive electrical repair shop around you.
They should be able to repair it for you to reinstall.
There is still such a place in Akron Ohio.
Kinda looks like a grungy hole in the wall sort of place.
Al the bays are full, with vehicles outside waiting.
Place has been Known for decades,as a reputable place.
Old Jan 30, 2023 | 02:03 PM
davidlieb's Avatar
Originally Posted by Wingrider
If there's an automotive electrical repair shop around you.
Interesting! Google doesn't seem to think that there is an automotive electrical repair shop near me...
Old Jan 30, 2023 | 02:06 PM
davidlieb's Avatar
I feel dumb, but I can't tell which part it is in this drawing I THINK it's #2?
https://parts.jaguarcary.com/oem-par...bC12OC1nYXM%3D
Old Jan 31, 2023 | 10:38 PM
Pete M's Avatar
Hi David,
At the point where the motor drive turns at right angles, there is a black cover plate with two torx screws. I wonder what you might find in there that is binding. Perhaps there are nylon gears that have a broken tooth, or something is caught between the gears? It would be worth checking it out.
Pete M
Old Feb 1, 2023 | 06:26 AM
Wingrider's Avatar
David trying just electrical motor repair.
Might find you someone, to refurbish your motor if necessary.
Old Jun 6, 2023 | 12:38 PM
cooldood's Avatar
Hi David,
Did you get this sorted?
It sounds like the same issue I am struggling with, will be my next task to fix.
I just replaced the motor gears on my X-type, but this is a different sound, those motors just ran freely as the broken plastic teeth meant there was no load.
In the XJ, there is is just that clunk as it preloads then finds it cannot move, so weak motor/brushes, or jammed mechanism maybe?
Thanks,
John
Old Jun 7, 2023 | 12:57 AM
Richardhw's Avatar
I had exactly this problem, it got sorted out by gripping the threaded part firmly and just twisting it a bit, it seems like the thread had reached the end of travel and just jammed in position, manually moving it did the trick for me and its working just fine now.
pcolapacker
Dec 29, 2023 07:08 PM
MK2
XJ40 ( XJ81 )
Dec 13, 2014 06:15 PM
45Wheelgun
Jul 4, 2011 12:34 PM
