DSC ABS problem
Old Apr 23, 2017 | 03:25 PM
LeeH's Avatar
Default DSC ABS problem
Hi everyone.
Looking for some guidance on DSC ABS issue with my 2003 XJ8 SE.
When I hit a dip in the road or bump it feels like the traction control kicks in and momentarily cuts engine power, sometimes just a gentle dip in the road can cause it.
Also been having occasional ABS/DSC fault coming up on the dash.
Any ideas anyone?
Thanks Lee
Old Apr 23, 2017 | 03:44 PM
jackra_1's Avatar
Could be dirt/rust on the sensors or even a loose connection.
If there is something wrong with the ABS system it will automatically cause the DSC not to function.
Old Apr 23, 2017 | 04:52 PM
LeeH's Avatar
Thanks for the advice.
Would this also cause the traction control/dsc to kick in and cut power when I go over bumps or dips in the road?
Old Apr 23, 2017 | 04:57 PM
jackra_1's Avatar
Possible.
If a sensor is fooled into thinking that a wheel is slipping then DSC will be activated.
Brake will be applied to wheel that it thinks is slipping.
Old Apr 23, 2017 | 04:59 PM
motorcarman's Avatar
Are any faults logged in the ABS module??
bob
Old Apr 23, 2017 | 05:06 PM
LeeH's Avatar
I don't have anything to read the fault codes stored i'm afraid.
Is there a way to pull the codes without one?
Old Apr 23, 2017 | 09:00 PM
No, but any other suggestions are GUESSING.
The module KNOWS what it thinks is wrong. The DTC will be logged as a fault.
Ask the MODULE.
Let the guessing continue.
bob
Old Apr 30, 2017 | 11:34 AM
LeeH's Avatar
Hi guys, bought myself a good scanner.
Left side rear wheel sensor tone ring tooth missing or damaged..
Will take a look and give both sides a good clean inspection and go from there.
Fingers crossed...
Old Apr 30, 2017 | 12:48 PM
jackra_1's Avatar
Fingers crossed...
If it is the "toothed" variety, as opposed to the "indented" variety I have one for the cost of postage.
Just noticed you are in the U.K so postage may be too much.
Old Apr 30, 2017 | 05:29 PM
meirion1's Avatar
These guys sell reluctor rings and are in lincolnshire:
ABS Reluctor Rings
