ECU
Old May 17, 2018 | 09:42 AM
Samuraipxi's Avatar
Default ECU
Hi, I own a 2008 Jaguar X type but unfortunately I can't use it.
I have a problem with the ECU, 7x43-12a650-ab. Water managed to attack the plug which caused a number of pins to drop out and now the car is unable to start. I bought a second hand replacement to have it reprogrammed but the Jaguar specialist told me he was unable to recode it due to security restrictions. Is there anywhere I can have the old ECU repaired or the replacement wiped so that it can be coded? I have only had the car 6 months and really need help getting it back on the road. Thanks, James
Old May 17, 2018 | 10:17 AM
jackra_1's Avatar
Default https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/2004-s-typ
https://www.jaguarforums.com/forum/s...cement-198284/
Have a look at the above thread. Not the same year as your car however problem is the same. Not good news tho.
Old May 19, 2018 | 06:36 AM
JagV8's Avatar
1. post in the correct forum
2. post your location
Old May 19, 2018 | 03:22 PM
Samuraipxi's Avatar
@jackra_1 - Thanks for the information I'll make sure to read throught the thread.
@ JagV8 - 1. I used the ask a question feature of the forum and it automatically chose which forum.
2. Why would I need to post a location? It has zero relevance to the thread.
Old May 20, 2018 | 09:19 AM
JagV8's Avatar
People who could repair it have a location.
If you don't want any suggests of appropriate repairers, fine.
Old May 22, 2018 | 02:41 PM
Blairware's Avatar
Posting to where folks have the same vehicle can increase your odds of getting a helpful reply. While your issue is generic, you never stated how the ECU pins got wet. If it is an issue that occurs more frequently in an X-Type, readers of that thread that have experienced the issue could provide a source for your ECU repair.
Stuart@VelocityAP
F-Pace (X761) / C-X17
85
Aug 12, 2024 08:22 PM
Stuart@VelocityAP
XE ( X760 )
166
Apr 14, 2024 11:14 AM
03_jagXJR
Jan 15, 2017 08:31 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
