engine checking light on
Old Dec 11, 2017 | 12:15 PM
mingstudios's Avatar
Default engine checking light on
I have this nice Jaguar xj8 with only 9600 miles on it. It has been running great. I have taken care of it regularly. But two days ago as I drove back from a long trip, its engine checking light turned on. The engine was running fine since and, beside the light, nothing was unusual. So I though it might need to have the oil changed. However, after the oil change, the light is still on. Can any one tell me if there is a reset button to turn off the light? Or something more has to be done as a routine maintenance?
Old Dec 11, 2017 | 12:23 PM
NBCat's Avatar
If the MIL is on, you need to have someone plug into the OBD port and provide you with the code(s). Once you have the code(s), post them here for some recommendations.
List the MY in your signature.
Old Dec 13, 2017 | 12:19 PM
Lagonia's Avatar
IMHO, someone that changes oil as a first reaction to when the check engine light comes on should probably stay away from older Jags - if you are not prepared those cats will eat you up (your wallet) for breakfast.
mgginva
Dec 13, 2017 07:39 AM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
j2times
May 16, 2017 02:27 PM
SteveSheldon
UK & Eire
Oct 3, 2016 05:03 PM
JimC64
Sep 10, 2009 12:44 PM
