Fault Codes
Old Apr 5, 2016 | 04:53 PM
JaguarLover101's Avatar
Default Fault Codes
Hello All,
I have a 2004 X350 Super V8 with a few fault codes:-
P2583 - Forward looking sensor
P1696 - Adaptive speed control CAN link
B2414 - Headlamp washer relay circuit short ground
U3FF6 - No description available
B2309-25 - No description available
B2309-31 - No description available
On the internet, I have found that the forward looking sensor is prone to corrosion so I will take a look at that and see how it is, is the second fault code linked to that?
The headlamp washer is apparently a non-serviceable relay... bugger! Or could it be something else?
I cannot find any information for the last 3, except the first one is from the rear electronics module and the other two are from the rear seat module, the only modifications to the rear of the car is a non-standard dvd player.
Could anyone help with diagnosing these?
Old Apr 7, 2016 | 01:07 AM
grantorino62's Avatar
Without the benefit of a service manual I would venture that the headlight washers are leaking onto the forward sensor as a best guess. Most car codes are in order of severity. Fix the first code and maybe the second then erase all codes to see if any return.
Arjtpa
16
Jan 10, 2025 11:12 AM
Jack Christmas
Oct 28, 2017 12:54 PM
hawaiianjag
Mar 17, 2016 05:58 PM
Paul Mason
Mar 13, 2016 01:10 PM
princemarko
Feb 26, 2016 04:50 AM
