Ok, I have the XJR. Now I am trying to order front pads on Summit Racing, but there are several different looking pads. (Yes, I have narrowed the search to font pads only)
Didn't all XJR's come with the Brembo calipers? Why are there different looking pads listed with different mounting tangs? Which one do I get?
TIA...
V
TIA...
V
Cambo
close
- Join DateJan 2011
- LocationSydney, Australia
Liked:4,525 Times in 2,445 Posts
Yeah you have Brembo's, have a look here for accurate details on the brakes
https://www.jaguarforums.com/forum/s...r-x350-103513/
Double-check the pad dimensions against the pictures.
Former Sponsor
SNG Barratt USA
Former Sponsor
close
- Join DateOct 2013
- LocationManchester, New Hampshire
Liked:533 Times in 277 Posts
If you want me to look these up I can do so & follow up with a part number and picture. Will just need your VIN.
Regards William@SngBarratt.Com
Don B
close
- Join DateFeb 2014
- LocationCrossroads of America
Liked:15,283 Times in 7,262 Posts
Cambo,
Your post on the Brembo brake options is outstanding! Thank you for doing the research and putting together such an informative report.
I notice that Mintex pads are not listed, but Mintex is a longstanding Jaguar OEM (since at least the '50s Le Mans-winning C- and D-Types), and it's quite possible, if not likely, that they made the original equipment "Jaguar" pads on the X350 XJRs. Mintex pads are reasonably priced and available in the U.S. from some of the good independent Jaguar parts vendors. Braking performance is excellent, with the one drawback that brake dust production is also equivalent to OE.
I wish I could have found Ferodo pads in the U.S. because I've had superb performance from them in our XJ40s in years past. If anyone knows of a U.S. source for Ferodos for the XJR fronts I would love to know. I found a source for the rears, but not the fronts.
I've also had excellent performance from Pagid pads in our BMW.
Cheers,
Don
Cheers,
Don
Quote:
Regards william@sngbarratt.com
Originally Posted by sng barratt usa
if you want me to look these up i can do so & follow up with a part number and picture. Will just need your vin. Regards william@sngbarratt.com
SAJWA73B74TG29938
Cambo
close
- Join DateJan 2011
I'd missed Mintex but it after a quick check they also list the correct pads to suit the Brembo cars so I'll add them to the FAQ.
Former Sponsor
SNG Barratt USA
Former Sponsor
close
- Join DateOct 2013
See below link for picture and price for the Mintex..
Part numbers for pads for your vehicle are
latest: C2C24018
Pre supersession: C2C8365
www.sngbarratt.com/ProductDetails.aspx?id=324c528f-f678-4bc1-b9e8-c6d406fceeb4
Hope this helps!
latest: C2C24018
Hope this helps!
latest: C2C24018
Hope this helps!
Originally Posted by SNG Barratt USA
See below link for picture and price for the Mintex..Part numbers for pads for your vehicle are
latest: C2C24018
Hope this helps!
Thanks. So the S-Type & XJR share the same pad styles?
Former Sponsor
SNG Barratt USA
Former Sponsor
close
- Join DateOct 2013
Stype supercharged-from (v) m45255 to (v) n52047
xj supercharged upto (v) g49700
Cambo
close
- Join DateJan 2011
Quote:
Same everything; pads, rotors, hoses, hubs, vertical links, wishbones, etc...only the shocks are different...Originally Posted by VinnyT
