Fuel cap click when tightened?
Old Nov 15, 2025 | 06:27 PM
Droneman's Avatar
Default Fuel cap click when tightened?
2004 xjr, cap tightens and stops, does not continue rotating and clicking. Is this normal?
Old Nov 16, 2025 | 03:49 AM
Petz's Avatar
Should be clicking several times
Old Nov 16, 2025 | 08:26 AM
Droneman's Avatar
Default Cap
Thanks Petz, I’ve ordered one off of Amazon, keeping fingers crossed no more 442 and 456 codes
Old Nov 16, 2025 | 09:05 AM
Petz's Avatar
Evap issue... ok worth a try. I changed an o-ring on the 4.2 na at the throttlebody entry and I pressed the connection near the strut the hose coming from the evap system in the left wheel well
Old Nov 16, 2025 | 11:27 AM
mjcarch's Avatar
I have ordered 2 OEM Jaguar gas caps for my 2004 XJR and neither of them click they just tighten down. I thought that was just a Jaguar thing but wish they would click to confirm the seal.
Old Nov 16, 2025 | 11:28 AM
Droneman's Avatar
Default Purge
I took off the purge valve, in the left front wheel well, couldn’t blow thru it, hooked it up to 12 volts and it opened I could blow thru it. I can’t hear any hissing, I’m at a loss if it’s not the fuel cap . I’ve put so many hours into this car to bring it back and now this dh$t! The charcoal canister is buried up above the differential.
Old Nov 16, 2025 | 04:14 PM
mikesch's Avatar
where did you get the O-ring. Can you show me a picture of the O-ring
Old Nov 17, 2025 | 02:18 PM
Petz's Avatar
No . Have a look where the hose enters the back of the throttlebody . There's a O -ring inside
Old Nov 30, 2025 | 09:00 PM
Droneman's Avatar
Default Fuel cap
New cap doesn’t click either, just tightens down after 1/4 turn. Still getting 442 and 456 codes, I’m going to have to bring it to someone.
MRomanik
Aug 18, 2018 09:46 AM
ciel-bleu
Jan 8, 2016 07:04 AM
topherscott
Sep 30, 2013 12:11 PM
dd823
May 23, 2012 12:10 AM
wcshelley
Nov 17, 2008 03:36 AM
