Fuel cap click when tightened?
Evap issue... ok worth a try. I changed an o-ring on the 4.2 na at the throttlebody entry and I pressed the connection near the strut the hose coming from the evap system in the left wheel well
I took off the purge valve, in the left front wheel well, couldn’t blow thru it, hooked it up to 12 volts and it opened I could blow thru it. I can’t hear any hissing, I’m at a loss if it’s not the fuel cap . I’ve put so many hours into this car to bring it back and now this dh$t! The charcoal canister is buried up above the differential.
where did you get the O-ring. Can you show me a picture of the O-ring
