Has someone already had this problem??
Old Sep 26, 2021 | 11:31 AM
Eric8's Avatar
Default Has someone already had this problem??
https://youtube.com/shorts/icBx5ghXzAw?feature=share
Completely blocked...
Old Sep 26, 2021 | 12:30 PM
FreeWifi's Avatar
Originally Posted by Eric8
Have you tried turning the wheel back and fourth while turning the key? Could be as simple as wheel being locked.
Old Sep 26, 2021 | 01:01 PM
Eric8's Avatar
Hello FreeWifi! What do you mean by "turning the wheel back and fourth while turning the key"?
Old Sep 26, 2021 | 01:08 PM
FreeWifi's Avatar
Turning the steering wheel right to left repeatedly while turning the key in the ignition.
Eric8's Avatar
The problem appeared after a locking of the steering wheel but now it is unlocked but I cannot enter the key completely
Old Sep 26, 2021 | 01:18 PM
Eric8's Avatar
Look -->
Old Sep 26, 2021 | 01:27 PM
FreeWifi's Avatar
Have any graphite you can lube the lock with? Seems the tumblers are jumbled up inside not allowing the key to fully insert. Think someone had luck inserting a small screwdriver into the lock and resetting the tumblers but I would be careful in doing so, wouldn't jam it in or anything.
Old Sep 26, 2021 | 02:17 PM
Eric8's Avatar
You are a genius! I have put a little cissors inside with lub and that unlocked everything. Thank you very much!!! :O
Old Sep 26, 2021 | 02:22 PM
FreeWifi's Avatar
Glad it worked.
Steve M
UK & Eire
Apr 23, 2020 04:41 AM
Jacb
Jun 10, 2018 12:09 AM
robert22225
XK120 XK140 XK150
May 18, 2018 02:26 PM
jagtoes
May 29, 2015 07:10 AM
bjg625
Nov 12, 2014 05:46 PM
