Has someone already had this problem??
Turning the steering wheel right to left repeatedly while turning the key in the ignition.
Have any graphite you can lube the lock with? Seems the tumblers are jumbled up inside not allowing the key to fully insert. Think someone had luck inserting a small screwdriver into the lock and resetting the tumblers but I would be careful in doing so, wouldn't jam it in or anything.
