Heater and diagnostics
Old Dec 23, 2016 | 12:23 PM
Generallee's Avatar
Default Heater and diagnostics
Hi, first post here. Just bought a 2004 X350 3 litre, nice car :-)
My heater is cold on the drivers side UK car - have read up on blocked heater matrix and done a flush/sterident etc, but no change, really cold - can the servos cause this? Dash out job for servo? What are people using for diagnostics? Obviously I would like to diagnose the climate control problem I have. Have a laptop with Windows 7 pro. Is there a way to read faults of the climate control screen? Many questions, Merry Xmas :-)
Old Dec 23, 2016 | 03:25 PM
clifton94's Avatar
Is your heater pump working
Old Dec 23, 2016 | 03:42 PM
meirion1's Avatar
A fault with the servos-I assume you mean the flaps in the CC box is very, very
unlikely.
The cause is either the pump referred to above by Clifton which is the small auxilliary
12 volt pump near top of radiator.
This is a pic of a nice new one:
https://www.google.com.au/search?hl=...wI42JpVidMM%3A
or a partially blocked matrix and if you can't flush it you will need to replace it.
I can be done by removing just removing the glovebox.
Old Dec 23, 2016 | 04:09 PM
Generallee's Avatar
Hi, is there a heater pump on the V6 3 litre petrol? I read it was just the V8? Can't believe there is so much difference on each side - passenger side is lovely and warm, drivers side is stone cold - just the tiniest bit warm, and I mean just not cold, even after a good run. Nothing appeared to come out of the matrix when flushed.
Old Dec 24, 2016 | 12:04 AM
meirion1's Avatar
Sorry I just assumed all x350,s had an aux pump.
If you have not got an aux pump then it will be the matrix.
Have a look at JTIS which you can download from this forum.
There are drawings for the cooling system on different engines.
The matrix blocks in such a way that a section is excluded from the flow
but you still get full bore flow at the outlet if you see what I mean.
Old Dec 24, 2016 | 02:34 AM
Generallee's Avatar
Hi, will get the lid open again today and take a look - anyone actually done a matrix change? My local Jag specialist seemed to think it would take 2 hours, so can't be that difficult.....can it?
Old Dec 24, 2016 | 04:34 AM
clifton94's Avatar
Hi you are right only the v8 has a pump when you flushed it did you flush it from both pipes
Old Dec 24, 2016 | 06:19 AM
Generallee's Avatar
Oh yes, had the hose pipe down it ;-) Looking like new matrix .
Old Dec 24, 2016 | 08:57 AM
Sean W's Avatar
The job is done from inside the cabin, at least on the V8's. The only thing you need to do under the hood is clamp the heater hoses to prevent coolant loss.
If your mechanic is saying 2 hours, let him do it. You're getting it done for a good price.
Old Dec 24, 2016 | 09:18 AM
Generallee's Avatar
Yeah, I have heard that is how to do it. I like a challenge though..... certainly going to remove the glove box and take a look ;-)
Old Dec 24, 2016 | 02:28 PM
meirion1's Avatar
I have never had to do this job myself so I can't give you chapter and
verse and I don't know if you realley need to remove blower etc. but
I do know that the clamps on the matrix are pathetic.
More info here:
https://www.jaguarforums.com/forum/x...lation-130143/
Matrix blockage is common on this Jag
Let us know how you get on.
Old Jan 6, 2017 | 12:15 PM
Generallee's Avatar
Wimped out and sent it in to be done 114+vat for the matrix, 3 hours labour+vat. So nice to have heating.... :-)
Old Jan 6, 2017 | 03:10 PM
meirion1's Avatar
Wow that a very reasonable price!
