Help in Gearhart/Portland OR
Old Jan 4, 2026 | 03:48 PM
eberle58's Avatar
Default Help in Gearhart/Portland OR
I have a 2008 Jaguar XJ and need someone to replace a headliner and fix a water leak and the deive side column. Any guidance would be appreciated
Thank you
Old Jan 4, 2026 | 05:06 PM
Don B's Avatar
Hi eberle58,
Welcome to the Jaguar Forums! It's great to have you with us.
I have moved your post from the forum for the X351 to the forum for the X350/X358. The Jaguar factory project code for your 2008 XJ is X358, which is the facelift version of the X350.
Here you will find knowledgeable owners of similar cars.
Cheers,
Don
Old Jan 4, 2026 | 05:33 PM
Big Koshka's Avatar
@eberle58 when I had to replace headliner in my car I was lucky to find local upholstery shop specialist in restorations. Just Google it in your area and talk to them. There are also few guys here from Oregon. They will advise you. BTW. Your car, is it a Long Wheel Base? Mine is SWB, and guy insisted on removing rear window. Some folks on this forum swear it can be done without. I just did not want to go against professional advise.
Welcome to forum and good luck!
Old Jan 5, 2026 | 09:07 AM
eberle58's Avatar
thank you big Koshka
marcela
Oct 13, 2021 03:54 PM
Henry D. Robinson
May 26, 2021 07:18 PM
chrisf
Oct 18, 2019 09:03 PM
Lannyl81
Feb 11, 2013 10:44 AM
