hid adjustment
Old Sep 19, 2014 | 09:33 AM
dvjag's Avatar
Default hid adjustment
Is it possible to make horizontal adjustment on the hid lights on my 2007 xj8 can see the vertical adjusters but cant see any others, thanks in advance,
regards
Dave
2007 xj8
Old Sep 19, 2014 | 04:17 PM
34by151's Avatar
Each lamp has 2 adjustment bolts
From memory the outer one is side adjustment and the inner is height
Both are located above the lap assembly
The outer is roughly above the center-line of the outer lamp
The inner is roughly between the lamps
Also remember the lamp height is controlled by the suspension system
So make sure you tyre pressures are ok and run the engine during adjustment
34by151
1983turbojaguarxj6
Jan 11, 2025 10:28 PM
Rocky15
Oct 12, 2015 03:42 AM
Johncy2000
Oct 2, 2015 01:05 AM
gunlocators
Sep 30, 2015 08:05 AM
