How can I open the trunk?
Old Jan 24, 2014 | 06:19 PM
tamscash's Avatar
Exclamation How can I open the trunk?
How can I open the trunk of my 2000 Vanden Plas. The key won't work, I don't have a remote and the car is stuck in valet mode.
Old Jan 24, 2014 | 06:58 PM
avt007's Avatar
Welcome aboard! You'll find this to be a fun and friendly group. Dig in, poke around, and ask lots of questions.
If someone's post is helpful, please thank them using the "thanks" button.
If you have good information on a problem, please share it.
Post some pictures of your car when you can.
As for your trunk, do a search for "trunk" in the X308 forum (BTW that's where this thread belongs) and you'll find lots of info. Basically, remove the licence plate and use a long screwdriver through one of the holes to pop the mechanism open.
Does the key not turn, or?
Old Jan 24, 2014 | 08:21 PM
tamscash's Avatar
I read on here about using a screw driver and can only see a screw on the left side of the right bottom hole. Is that where I need to look? If I could get it out of valet mode I could use the button.
Old Jan 25, 2014 | 03:02 PM
meirion1's Avatar
Have you tried locking and then unlocking the car to get it out of valet mode?
Old Jan 25, 2014 | 04:47 PM
avt007's Avatar
Under the plate there are some black plastic bits of tape over some holes. I had luck going through the bottom left hand hole and feeling around with a screwdriver.
What happens when you try the key?
Old Jan 26, 2014 | 04:42 AM
Fraser Mitchell's Avatar
BTW this is not the forum for your car. Try posting in the X308 forum
Old Jan 26, 2014 | 08:36 AM
tamscash's Avatar
It doesn't turn all the way. It has opened it in the past but doesn't anymore
Old Jan 26, 2014 | 09:12 AM
tamscash's Avatar
yes but it didn't work. any other suggestions?
Old Jan 26, 2014 | 12:30 PM
avt007's Avatar
Spray WD40 or similar lube into the key hole and work the key back and forth.
Old Jan 29, 2014 | 07:14 PM
tamscash's Avatar
got the trunk open! sill in valet mode.Thank foe your help!
BadKat174
May 26, 2023 12:29 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
DuhCar
Sep 11, 2015 10:58 AM
findre
Sep 10, 2015 05:46 PM
speacock
Sep 10, 2015 12:14 AM
