How do you replace the blade in the remote?
Old May 9, 2025 | 06:42 AM
Jaroslav Záruba's Avatar
Default How do you replace the blade in the remote?
Would anyone happen to have pics showing a disassembly of the front half of the remote?
I.e. if I wanted to buy this thing below and plug it into a remote keyfob...?
Old May 9, 2025 | 08:56 AM
OutpostJaguar's Avatar
I’m interested in this as well. I have a cut blade on a key that’s not transmitter programmed to the car but was just thinking to transfer the nice new blade over to one of my other keys.
Old May 9, 2025 | 09:06 AM
Thomas-S.'s Avatar
You have to pry open the case as it is glued together. Not nice, but unavoidable.
Theny ou are able to remove the blade assembly, which is basically the blade iteself and the release button. The blade itself is fixed to the rest via a splint that you can remove to replace the blade.
Then you reassemble the whole and glue the case back together.
I did it because the blade button on my remote did not have the growler, but unfortunately I did not take pictures.
There is a thread in the forum about the key and remote fobs, maybe thee are some pictures there.
Best regards,
Thomas
Old May 9, 2025 | 07:32 PM
That's exactly why I am interested in the topic.
I suppose you mean this one: Jaguar Key Fob 2001 to 2009 Facts All You Need to Know FAQ
...still leaves some room for imagination about how the blade is fixed in the leaf-shaped thing.
Best regards,
Thomas
Old May 9, 2025 | 07:35 PM
I have been living under the impression you can program the transmitter/transponder using the SDD: Programming keys with SDD
Old May 11, 2025 | 02:34 PM
Thomas-S.'s Avatar
Hi,
do you see the "black dot" ronthe right of the blade in the "leaf shaped thing"?
That's the splint I was referring to that fixes the blade. You need to either press it out, or you can hammer it out with a nail (or something similar) and hammer.
Best regards,
Thomas
Old May 11, 2025 | 03:27 PM
Wingrider's Avatar
Sort of a spring type rivet, to be driven out, & then back in.
Old May 14, 2025 | 02:06 PM
hafren's Avatar
It is a roll pin. Just tap it out, replace blade and refit. Done it on 2 of my keys. Easy peasy.
Nickts
F-Pace (X761) / C-X17
Jan 27, 2023 09:18 AM
1992weezer
Feb 12, 2018 11:23 AM
05XK8cfe
Nov 4, 2014 07:53 PM
rolexmike
XJ40 ( XJ81 )
Oct 20, 2010 09:40 PM
