How Does This Come Off?
Old Mar 16, 2024 | 02:13 PM
04Xjrsteve's Avatar
Default How Does This Come Off?
The attached image is of a plastic connector (screw-like) ) that attaches insulation to the false bulkhead wall behind the engine. From the backside it looks like the pictured disk should pullout a pin that spreads the plastc thread. I tugged on the disk & was concerned that it might break. Does anyone know how to remove?
Old Mar 16, 2024 | 03:09 PM
JoeDredd's Avatar
Is there a pin in the centre that pushes through? I know there are some that do that.
Old Mar 16, 2024 | 05:09 PM
04Xjrsteve's Avatar
Thanks! Yes, there is a pin in the middle, but won't pull out. I'm concerned about pulling too hard.
Old Mar 16, 2024 | 06:32 PM
motorcarman's Avatar
Probably need to push the pin MOST OF THE WAY IN (try not to lose it) and then remove the fastener.
Old Mar 16, 2024 | 11:16 PM
farm-jag's Avatar
Honestly, not being negative, but expect that it'll break. Usually does with these plastic pieces. Good news, you can get all kinds of replacements that are as good, or better, than what you have here. Doesn't need to be OEM at all. I get the hesitation, I used to be the same way, but since I bought a variety pack of all sorts, I still try to keep original, but not very hard and if they break, it's no big deal anymore.
Old Mar 17, 2024 | 02:57 AM
04Xjrsteve's Avatar
Default Great Point!
Coincidently, while searching for gas line clips in order to remove the fuel pump, I saw a bag of such fasteners. I will search further.
Old Mar 17, 2024 | 03:00 AM
Pete M's Avatar
These are known as fir tree fasteners and just hold by friction. Use a trim tool to slip under the head and lever it out. As stated above, they are readily available and cheap.
Fir tree fastener
Pete M
Mozambique
Jan 12, 2024 04:05 PM
Aarcuda
Apr 13, 2023 10:47 AM
nd4spdlsc
Jul 5, 2018 02:12 PM
JensenHealey
Feb 25, 2018 08:22 AM
erobbins
Feb 13, 2018 08:59 AM
