How to Program New Key Remote
Old Nov 24, 2016 | 01:05 PM
Jhamaine's Avatar
Default How to Program New Key Remote
Can I program a new cut by dealer key without a computer?
Old Nov 24, 2016 | 01:39 PM
Don B's Avatar
Hi Jami,
Welcome to the Jaguar Forums! It's great to have you with us. For the benefit of other members, I've taken the liberty of revising the title of your thread so it describes the nature of your question.
Yes, you can program a new key yourself if it has the transponder in the key. You must program all your keys/remotes at the same time. Here are the steps:
1. Open driver's door;
2. Pull and hold the high beam selector lever toward you;
3. Insert the key in the ignition lock and turn it to Position I (Accessory);
4. Release the high beam selector lever and then pull and release it 4 more times. After the 4th time you will hear a chime;
5. Now press the lock button on each key remote, one after another, to program them in.
6. Once you've programmed the last remote, you're finished. Turn the key to the Off position and test each remote to ensure proper operation. Repeat the programming process if necessary.
If any of your remotes needs a new battery, the size is CR2032.
Cheers,
Don
Old Nov 25, 2016 | 12:13 AM
Jhamaine's Avatar
Default Jami
Originally Posted by Don B
Hi Jami,
Cheers,
Don
I should be getting my new cut key from the dealer by next week and hopefully this works, as I am states away from my nearest dealer. Thankyou.
Old Nov 25, 2016 | 03:02 AM
This is the 2003-2009 X350 & X358 forum and I see from other posts that you have a 1998 XK8 where you already have the same question posted.
THREAD CLOSED
rudelover2
Nov 29, 2016 07:41 AM
Jhamaine
Nov 26, 2016 12:53 PM
CWMcGonigal
Nov 25, 2016 08:23 AM
Poet
Nov 22, 2016 10:33 AM
marcoxpolo
Nov 18, 2016 07:51 PM
