ICarSoft i930 Update
Old Jan 17, 2016 | 10:53 PM
Mark in Maine's Avatar
Default ICarSoft i930 Update
Hears the disclaimer- No affiliation with the manufacture.
After checking for charging issues, I went deeep into the options. This thing will almost tell me everything the car is doing between live data and some of the other options. It even told me about the time I over extended the seat travel. Best money I've spent on the car other than BT streaming and new tires. There are other options out there also, including throwing a lot of parts and money at it with alot of prayer. Thanks to all that turned me on to this.
Beware--- It might also tell you things you dont want to know. Like bad fuel trims and vaccum leaks.
Mark
Old Jan 18, 2016 | 09:30 AM
chillyphilly's Avatar
Awesome, thanks for the update Mark! I keep wanting to get the original Mongoose and software, but keep coming back to the icarsoft, as I don't know if I want to deal with the headaches of the SDD.
Old Jan 19, 2016 | 06:08 AM
Lagonia's Avatar
It would be nice to have someone that has both (SDD and i930) compare the two. I do have the SDD with the real Mongoose cable and I use it sparingly. I am happy with it even though it is not easy or intuitive for sure.
Old Jan 19, 2016 | 01:18 PM
The Icar will only report data, and test certain systems. The SDD I believe can also change certain settings, turn on and off various features/functions, and read certain propriatary Jag systems. Someone can chime in with SDD experiance. I am mostly concerned with data and system reporting for trouble shooting purposes, and am not really concerned about turning on/off features. Although having the abillity to check and adjust suspension systems in detail would be nice.
One of the great features of the Icar, is it will report transmision fluid temp. This will be great for the upcomming fluid change. More accurate than the IR thermometer, although the IR thermometer will get the job done.
Old Apr 3, 2016 | 09:09 AM
Ludovic Card's Avatar
Hello, everybody, i have a 2005 x type estate 2.0 D, and i just want to know if its possible to read fault code of abs sensor and parking sensor in order to change it myself. Thanks a lot and sorry for my poor english, i live in France and i'm a little bit rusty.
Old Apr 4, 2016 | 05:09 AM
meirion1's Avatar
I do not think you will get a code for a faulty parking sensor.
See my post for repair here:https://www.jaguarforums.com/forum/xj-xj6-xj8-xjr-
x350-x358-28/parking-sensor-problems-160549/
You may be able to repair ABS sensor by sustituting a good one in each position.
ie try a good one in every wheel in turn.
Old Apr 4, 2016 | 06:29 AM
PDMiller's Avatar
I find the iCarSoft i930 fine for my 2004 X350, but not so good on my 2001 XK8 and pretty hopeless on my Wife's P38 Range Rover ,even though it does Landrover and Jaguar models. I see that there's now a second generation model which apparently does a lot more than the original. I'm wondering if it would do stuff like re-set the air suspension on the Range Rover and do the live data thing on the XK8. Maybe I would be better with the Mongoose.
This is all a bit confusing to old Grease monkeys like me and a challenge to keep up but hopefully it stops the old grey matter from seizing up
Old Apr 4, 2016 | 10:50 PM
I feel the same way about mine. Works wonders on mt 06 SV8, but very basic on my wifes P38. Please tell me that this doesnt mean that we have to get our wives new Range Rovers !
Old Apr 5, 2016 | 05:05 AM
clifton94's Avatar
My icarsoft told me what reverse sensor was faulty I think when I done mine I put the car in reverse then the module is then active
nobodyspecial
May 25, 2016 10:03 AM
Onedark1
Feb 3, 2016 10:56 AM
jaguarguy13
XJ40 ( XJ81 )
Jan 14, 2016 11:03 PM
cully
Jan 14, 2016 02:57 AM
cully
Jan 12, 2016 11:14 AM
