Keys stuck in ignition
Old Mar 20, 2011 | 12:30 PM
amcdonal86's Avatar
Default Keys stuck in ignition
I seem to have had a problem twice this weekend removing the key from the ignition. It doesn't seem to want to come out of the ACC position, and I end up having to restart the car and/or move the shift lever from P to D back to P and then shut it off again. Then it comes out. What could be causing this? Am I missing something?
Old Mar 21, 2011 | 09:53 AM
kthrash's Avatar
Make sure you have it all the way in Park before turning it off.. I have found that if mine is not all the way to P and I shut it down I have to put my foot on the brake and cycle the transmission lever to N then back to P to get the key out..
Old Mar 21, 2011 | 10:07 AM
amcdonal86's Avatar
This is definitely a possibility. I wonder if the little shift lever connection thing on the outside of the transmission that I keep hearing about is coming loose. I hear that those two screws can fall out easily!
Old Nov 18, 2018 | 07:12 AM
Juwan Ciers's Avatar
Default Hey stuck in ignition
Hi someone help. Last night I made a mistake and cut the car off in neutral I put the car in park and now the key won't come out in the car won't start please help
Old Nov 18, 2018 | 01:15 PM
exiledbrit's Avatar
I would almost guarantee the car is not in Park. Those two bolts holding the shift cable are loose or missing. Very easy to check and fix
Steve
dsnyder586
Dec 29, 2024 07:39 PM
XJsc-guy
Nov 23, 2015 01:56 PM
Clamdigger
Sep 12, 2015 03:43 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
