Knock sensor replacement
Old Nov 27, 2012 | 06:18 PM
Gribblet's Avatar
Default Knock sensor replacement
Any ball park figures for getting a knock sensor replaced?
Old Nov 28, 2012 | 10:52 AM
Gribblet's Avatar
Default Additional Question
I have a 2004 XJ8 4.2 and am still unclear as to the location of the knock sensors on my engine. Are they in fact under the intake or not? Any pictures that you can share?
Old Nov 28, 2012 | 03:16 PM
Fraser Mitchell's Avatar
My Technical Notes shows the location of the engine sensors, and there are two knock sensors, one seems to be located under the inlet manifold, and the other at the front of the engine, again in the V ,but its not wholly clear.
Do you need to replace them ?
Old Nov 28, 2012 | 09:08 PM
jimlombardi's Avatar
Here is an engine controls locations illustration extracted from the JTIS manual - 2004 XJ Engine NA:
JTIS manual mentions removal of the intake manifold (including throttle body) to get to the LH knock sensor.
Jim Lombardi
Old Dec 26, 2012 | 10:29 PM
wordman's Avatar
do you need to drain the coolant to remove the air plenum to see if the connection at the knock senor is loose?
PMKimpton
Aug 3, 2019 08:22 PM
tberg
Sep 7, 2015 07:32 AM
KarimPA
Sep 3, 2015 07:32 PM
innzane
Sep 2, 2015 10:08 AM
TC Johnson
Sep 2, 2015 09:30 AM
