A lot of Fault Codes..
Old Sep 26, 2021 | 11:14 AM
Mikehill596's Avatar
Default A lot of Fault Codes..
Hello All,
Back with the XJR (@115k miles) today and have a collection of error codes:
P0783 - Gear selection 3-4 shift malfunction (Pending) - Im hoping this is due to needing an oil change, if anyone has any knowledge on this please let me know!
P1647 (x2) - Control unit 11 - im assuming these are lambda issues? (1x pending 1x confirmed)
P0353/4 - Ignition coil C/D primary/secondary - circuit malfunction - Im assuming these are meaning I need new coil packs? (Pending)
Any help or advice appreciated...
Old Sep 26, 2021 | 11:21 AM
NBCat's Avatar
Begin your diagnosis with reading the battery voltage with a voltmeter across the terminals.
With the ignition in the OFF position, there should be a minimum of 12.6 volts present. If not, charge the battery for five hours at 2 to 5 amps and retest. If there is still less than 12.6 volts, the battery is failing or weak and must be replaced prior to performing any further diagnosis. A failing or weak battery can cause random DTCs and instrument cluster warnings.
Old Sep 26, 2021 | 11:22 AM
Didnt think of that! could explain the central locking intermittent issue too.. I will plug the CTEK on now pre-emptively, cant do any harm
Old Sep 26, 2021 | 11:38 AM
xalty's Avatar
fix your misfires they cause horrible shifting
if p0783 still comes back after your transmission is most likely done
Old Sep 26, 2021 | 11:44 AM
And that would mean new auto box time?
Old Sep 26, 2021 | 12:11 PM
xalty's Avatar
if fluid isn’t low then yes
p0783 is the kiss of death
Old Sep 26, 2021 | 01:40 PM
Just got under the car and looks like a leak from the box, hoping its just a seal and the fault is due to low oil..
Old Sep 27, 2021 | 07:06 AM
So, an update on this. I bought the car for £4200 with 115k miles, I think thats a pretty good deal if I can sort the issues cheap enough, im lucky enough to work in the industry so ive just picked up a new transmission filter for free, I will be testing the battery and fuses tomorrow.
Issues: Passenger door not opening inside or out, passenger window wont close on driver control module (will on pass one), Gearbox fault (looks to have a leak so hoping thats all I find...) 2x lambda warnings, 2x ignition coil warnings, Snapped o/s parking brake cable
Ive got until November the 12th to have this ready for a road rally event over 800 miles...
Parts ordered so far, transmission filter, service kit, caldoofy intake, K&N filter.
Waiting on further diagnostic before ordering the ignition coils and lambda sensors.
Struggling to source parking cable...
Old Sep 27, 2021 | 09:02 AM
Forgot to add, when i use the wash wipe system it cuts the engine out.. possible front electronic module?
Old Sep 27, 2021 | 09:31 AM
Another thought, subframe shows corrosion, could be a ground issue?
Ross Von Brobyn
Apr 29, 2020 08:26 AM
looneytunes
Jul 5, 2019 02:45 PM
XKR1975
Mar 21, 2016 09:03 PM
Alan E L
Apr 18, 2013 09:01 PM
GeorgiaXJ8
Nov 16, 2009 07:42 PM
