Lower Bolt size for Front Air Shock?
Old Jan 5, 2012 | 08:01 AM
reyesl's Avatar
Default Lower Bolt size for Front Air Shock?
Help Please, I did a search on this Forum, IE, and Google, did not find anything relating to "what is the size of the Star Bolt" on the front shocks. I have up to a T55, but it has a little too much play so, I am assuming it is a T60? I need to know before I spend money on tools that I do not need (I have a shop full of those).
Attached Thumbnails Lower Bolt size for Front Air Shock?-lower-shock-mount-bolt.jpg
Old Jan 5, 2012 | 11:18 AM
Moving you to the X350 section.
Do you not have a friendly local garage that will lend/hire you a seldom used tool.
My local guy is partial to J&B, hint hint.
Old Jan 5, 2012 | 12:00 PM
reyesl's Avatar
Oh man, do I wish there is a friendly garage here! I live near a military base so, all they want is $$$$$.
I did have the local Dodge dealer hook-up the scanner for free, they wanted to look in my VDP.
I might ask them politely.
I would like to have my own tool, I have my own shop in back and have most tools, including engine rebuilding, body work, painting, and also wood-working tools. I have a Snap-on Scanner but it only goes to 2000. I purchased an 3100E last week to check my Engine Light fault.
Old Jan 5, 2012 | 03:39 PM
MK 82's Avatar
Banned
It is a T60.
Old Jan 5, 2012 | 11:35 PM
reyesl's Avatar
I purchased the T60 socket and removed the old shock and will be installing the new shock tomorrow.
Old Jan 7, 2012 | 03:43 AM
reyesl's Avatar
Took the VDP out for a test drive
No issues with the height sensor, compressor, shock, or air-line.
(None that I noticed)
Follow Arnott's Instructions!
I used 2 hyd floor jacks and 2 jack stands for safety. Also keep in mind that when you are lifting at the jack points, the whole side will lift-not just that corner (Safety).
Attached Thumbnails Lower Bolt size for Front Air Shock?-suspension-relay-r1-.jpg   Lower Bolt size for Front Air Shock?-remove.jpg   Lower Bolt size for Front Air Shock?-upper-ball-joint.jpg   Lower Bolt size for Front Air Shock?-rf-shock-mount.jpg   Lower Bolt size for Front Air Shock?-height-sensor-link-1.jpg
Lower Bolt size for Front Air Shock?-new-arnott-shock.jpg   Lower Bolt size for Front Air Shock?-mounting-bolts.jpg
kelliott
May 31, 2022 05:26 PM
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
tberg
Sep 7, 2015 07:32 AM
XJsc-guy
Sep 2, 2015 11:43 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
