Lumbar support fault
Old Jun 19, 2010 | 06:33 PM
user 2029223's Avatar
Banned
Default Lumbar support fault
When I adjust the drivers lumbar support it works like it should. But then, over a 30 minute period it goes away (deflates) and requires a complete readjustment (pump up). I,m assuming it's a neumatic system-it feels like it.
Any ideas to try before I take it to the dealer? The car is still under Select Edition Warranty but it is a 50 mile trip to the dealer and I,m looking for tips to try before going in.
Old Jun 22, 2010 | 07:16 AM
Banned
Anybody?
Where did everybody go?
Old Jun 22, 2010 | 08:57 AM
Drew's Avatar
It's an air bladder and it must be leaking. Unless you feel like taking the seat apart.....I would use the warrenty. Just call them and make sure it is covered so you don't waste a trip.
Old Jun 22, 2010 | 12:10 PM
Banned
My car is still under Select Edition Warranty so I hope it's covered for lumbar support faiulres, but let tell me you, Select Ed excludes more things than it includes. Got my fingers crossed.
Old Jun 22, 2010 | 01:14 PM
Drew's Avatar
Well if it doesn't you would have to pressurize the lumbar, remove the seat, take it apart and spray soapy water all over the plumbing. My guess would be the bladder itself or the release valve. That the moving parts and they ussually wear first. If you have to go that route, take some pics.
Here's from JTIS, "Lumbar MotorsThe front and rear seats have a two or four way lumbar motor system depending on the specification of the vehicle. The system uses a single motor driven pump, which inflates or deflates air cells, as required, to provide upper and lower lumbar support. The lumbar motors are operated from the seat control switches. Depending on the direction the switch is operated in, one of four solenoids housed within the solenoid pack (integral component of the lumbar assembly) is connected to the pump, which provides lumbar support by adjusting the amount of air in the appropriate cell."
JaguarLover101
48
Jun 12, 2023 10:28 AM
RedRider48
Oct 1, 2015 08:18 AM
dmatthewman
Sep 30, 2015 10:10 AM
zoozth
Sep 29, 2015 07:28 AM
