New Shock - Loud Noise
Old 02-16-2019, 10:04 PM
donniefitz2's Avatar
Default New Shock - Loud Noise
Hey, all. Hoping someone might have some input regarding a new shock install. My 2004 XJR had a leaky shock on the left front side. Oddly, it would only leak when really cold and as the day went on it was fine. Anyway, I decided to buy a replacement on Amazon. The brand was Doorman and it was cheap. But, when the part arrived, to my surprise, it was a factory Billstien shock. I was pretty excited about that. Anyway, I installed it and all went well.
The new shock filled up with air and no suspension faults. I took it for a ride and it seemed fine, until I went over a speed bump and it made an awful, loud sound, like rubber rubbing against metal. It only happens on a fairly large bump but it sounds bad, very bad and very loud.
I double checked to make sure I didn't leave anything loose and all looked well. The lower part of the shock does seem to be off center to with the main, larger portion. I'm thinking I just got a bad shock? Do these shocks make noise when new? Is there some break in to be expected? I really don't want to pull the damn thing off.
Old 02-17-2019, 11:53 AM
Wingrider's Avatar
Does not sound good to me
Look at other front shock, to see if it looks off center.
Contact the seller, then Amazon if there is an issue.
Don B (02-19-2019)
Old 02-22-2019, 01:41 PM
Ended up returning the shock because it appeared to be bent. Got an Arnott from Rock Auto for $350 and it worked out great.
Old 02-22-2019, 04:59 PM
Wingrider's Avatar
2888 front shocks are on my 04, no complaints.
2xlooser
08-18-2011 08:20 AM
H20boy
General Tech Help
10-31-2010 08:27 PM
kayeted
09-29-2009 05:29 PM
jimbojd1
01-14-2008 03:40 PM
Quick Reply: New Shock - Loud Noise
