The following comes from https://www.jaguarfortlauderdale.com...uble-codes.htm. I reformatted it to make it more readable.
Unlike some charts I have read, this one appears to have been written by a mechanic, not an engineer. It points to specific problems, although the term "wiring issue" could be expanded to point to specific wires (location, colour code, typical problem).
It would be very helpful if someone technical on this forum could take this list, put it into something like Wikipedia for cars, so each of us could add to each code when we encounter it. For example, where it says PCM failure, a photograph of the PCM location, the wires that go to it, how to get it out, and if it is sold by 3rd party vendors, where to buy it (as well as Ford equivalents, if applicable). Anyone with technical knowledge who could do this for us?
P0010
• Powertrain Control Module (PCM) failure.
• Variable valve timing actuator failure.
• Wiring issue.
P0011
• Camshaft variable timing solenoid failure.
• Engine oil level is too low.
• The engine is not timed correctly.
• The engine oil does not meet the manufacturer's requirements.
• Worn timing chain.
P0012
P0013
• Wiring issue.
P0014
P0101
• Large vacuum leaks.
• Split Intake Air Boot or PCV Hose.
• Defective intake manifold gaskets.
• Mass Airflow Sensor (MAF).
• Mass Air Flow Sensor circuit and or wiring problems.
• Defective Barometric Pressure Sensor.
• Dirty or contaminated Mass Air Flow Sensing wire or filament.
• PCM software needs to be updated.
P0102
• The Mass Airflow Sensor (MAF) Sensor is unplugged or the wiring is damaged.
• Loose or corroded electrical terminals in the MAF Sensor circuit.
• Faulty MAF Sensor.
P0113
• Defective Intake Air Temperature Sensor.
• Dirty air filter.
• Defective Mass Air Flow Sensor.
• Faulty or corroded Intake Air Temperature Sensor wiring or connections.
P0128
• Defective Engine Thermostat.
• Defective Engine Coolant Temperature Sensor.
• Defective Cooling System.
• Low Engine Coolant.
• Dirty Engine Coolant causing incorrect Coolant Temperature Sensor readings.
• Defective/always running Engine Cooling fan(s).
P0135
• Defective Oxygen Sensor/Air Fuel Ratio Sensor.
• Defective Oxygen Sensor/Air Fuel Ratio Sensor Heater Circuit.
• Exhaust System Leak.
• Intake Air System leak.
• Low Fuel Pressure.
• Defective sensor wiring and/or circuit problem.
• Defective PCM.
P0171
• Control module software needs to be updated.
• Vacuum leaks (intake manifold gaskets, vacuum hoses, PCV hoses, etc.).
• Mass air flow sensor.
• Plugged fuel filter or weak fuel pump.
• Plugged or dirty fuel injectors.
P0174
• Vacuum leaks (Intake Manifold Gaskets, vacuum hoses. PCV hoses. etc.).
• Faulty Mass Airflow (MAF) Sensor.
• Plugged Fuel Filter or weak Fuel Pump.
• Plugged or dirty Fuel Injectors.
P0200
• Defective Fuel Injector.
• Faulty or corroded Fuel Injector, wiring and/or connections.
• Plugged Fuel Injector.
• Dirt in the Fuel Injector.
P0201
• Faulty or corroded Fuel Injector, wiring. and/or connections.
P0202
• Malfunction of the Fuel Injector.
• Malfunction of the PCM Fuel Injector driver circuit.
• Defective wiring/connections in the Fuel Injector wiring harness.
• Defective Fuel Injector power circuit(s).
P0203
• Fuel injector failure.
• Wiring issue.
P0205
• Wiring issue.
P0300
• Worn out spark plugs, ignition wires, coil(s), distributor cap and rotor (when applicable).
• Incorrect ignition timing.
• Vacuum leak(s).
• Low or weak fuel pressure.
• Improperly functioning EGR system.
• Defective Crankshaft and/or Camshaft Sensor.
• Defective Throttle Position Sensor.
• Mechanical engine problems (i.e.—low compression, leaking head gasket(s), or valve problems).
P0301
• Vacuum leak(s).
P0302
• Vacuum leak(s).
P0303
• Vacuum leak(s).
P0304
• Vacuum leak(s).
P0401
• Restriction in the EGR passages usually caused by carbon buildup.
• The EGR Valve is defective.
• Lack of proper vacuum or electrical signal to the EGR valve.
• Malfunctioning EGR Vacuum supply solenoid.
• Lack of proper EGR system feedback to the computer from the: Manifold Absolute Pressure Sensor (MAP).
• Differential EGR Pressure Feedback Sensor (DPFE).
• EGR Valve Position Sensor (EVP).
• EGR Temperature Sensor.
P0420
• Inefficient Catalytic Converter(s).
• Defective Front or Rear Oxygen Sensor(s).
• Misfiring engines.
P0430
• Defective Catalytic Converter.
• Internal engine damage resulting in high oil consumption and/or a leaking Head Gasket has damaged the Catalytic Converter.
P0440
• Missing fuel cap.
• Defective or damaged fuel cap.
• Distorted or damaged Fuel Tank Filler Neck.
• Torn or punctured Evaporative system hose(s).
• Defective Fuel Tank Sending Unit gasket or seal.
• Split or damaged Carbon Canister.
• Defective Evaporative Vent Valve and/or Evaporative Purge Valve.
• Defective or damaged fuel tank.
P0441
• Missing fuel cap.
• Stuck open or closed purge valve.
• Distorted, damaged or cracked Fuel Tank Filler Neck.
• Defective Evaporative Vent Valve.
P0442
• Small tear or puncture in the Evaporative system hose(s) and/or Carbon Canister.
• Small split in a seam of the Carbon Canister.
• Defective or damaged Fuel Tank.
• Defective Fuel Tank Pressure Sensor.
• Defective Leak Detection Pump.
• Slightly loose and/or worn clamps or hardened O-rings anywhere in the EVAP system.
P0455
• Missing fuel cap.
P0500
• Defective Vehicle Speed Sensor.
• Defective Speedometer.
• Vehicle Speed Sensor wiring or connector.
• Communication (CAN) bus problems.
• Defective transmission or differential Vehicle Speed Sensor drive gear.
P0501
P0505
• Defective Idle Air Control Motor.
• Intake Manifold Vacuum leaks.
• Carbon buildup in the Throttle Body air passages.
P0506
• Defective/sticking Idle Air Control Motor.
• Defective Power Steering Pressure Switch.
P0507
• Defective Coolant Temperature Sensor.
• Defective Charging System/Alternator.
P0600
• Defective PCM (Power Train Control Module).
• Defective PCM data bus wiring/connections.
• Defective PCM data bus ground circuit(s).
• Defective PCM or other control module controlled output devices.
• Defective CAN bus communication.
P0601
• Lack of proper voltage to the PCM.
• Defective PCM memory module.
• Defective PCM ground circuit(s).
• Defective PCM controlled output devices.
P0602
• Wiring issue.
P0603
• Lack of proper voltage to the Keep Alive Memory connection on the PCM.
• Defective PCM Keep Alive Memory Module (KAM).
P0605
• Lack of proper voltage and/or ground to the PCM.
• Defective PCM ROM memory module.
P0700
• Defective Shift Solenoids.
• Defective Valve Body.
• Dirty transmission fluid that restricts the hydraulic passages.
P0705
• Defective Transmission Range Sensor (PRNDL input).
• Defective Transmission Range Sensor (PRNDL input) wiring or connector.
• Defective manual shift valve linkage.
P0706
P0720
• Defective Output Speed Sensor.
• Defective Output Speed Sensor wiring or connector.
P0730
P0841
• Transmission Control Module (TCM) failure.
• Transmission fluid level is low.
• Transmission fluid pressure sensor failure.
• Wiring issue.
P0842
• Wiring issue.
P0845
• Wiring issue.
P0846
• Wiring issue.
P0847
• Wiring issue.
P0901
• Clutch master cylinder failure.
• Clutch solenoid failure.
P0935
• Hydraulic power unit assembly failure.
• Wiring issue.
P0942
• Wiring issue.
P0944
• Clogged transmission filter.
• Transmission oil pump failure.
• Wiring issue.
P0961
• Transmission shift solenoid failure.
P0A08
• Inverter/converter assembly failure.
• Wiring issue.
P0A0D High voltage safety device failure.
• Power management control module failure.
• Service disconnect plug is not properly connected.
• Wiring issue.
P0A0F Hybrid transaxle assembly failure.
• Internal engine failure.
P0A7F Poor connections at the HV battery.
• A problem with the HV battery.
• ECU issues.
P0A80
• High voltage battery assembly failure.
P0B22
• Battery contactor assembly failure.
• Battery Energy Control Module (BECM) failure.
P0B24
• Wiring issue.
P0B26
• Wiring issue.
P0B28
• Wiring issue.
P0B30
• Wiring issue.
P0C00
• Drive motor generator power inverter control module failure.
P0C09
• Drive motor generator assembly failure.
P0C11
• Coolant system leak.
• Engine cooling fan failure.
• Water pump failure.
P0C14
P0C15
P2000
• Diesel Particulate Filter (DPF) failure.
• Intake air leak.
• Mass Airflow (MAF) sensor is dirty/loss of calibration.
PP2002
• Intake air leak.
P2004
• A failed IMRC actuator.
• A problem with the intake manifold or linkage.
• Wiring issues.
P2006
• Intake manifold runner control actuator failure.
• Restricted vacuum lines.
P2101
• Accelerator Pedal Position (APP) assembly failure.
• Throttle control motor failure.
• Wiring issue.
P2122
• Wiring issue.
P2135
• Throttle Position Sensor (TPS) failure.
• Wiring issue.
P2138
• Wiring issue.
P2181
• Engine coolant heater failure.
• Engine coolant level is too low.
• Thermostat failure.
P2210
• NOx sensor failure.
• Wiring issue.
P2213
• Wiring issue.
P2237
• Exhaust leak.
• Oxygen sensor failure.
• Wiring issue.
P2238
• Exhaust leak.
• Wiring issue.
P2251
• Exhaust leak.
• Wiring issue.
P2302
• Ignition coil failure.
• Wiring issue.
P2303
• Wiring issue.
P2305
• Wiring issue.
P2308
• Wiring issue.
P2310
• Wiring issue.
P2401
• Evap leak detection pump failure.
• Wiring issue.
P2402
• Wiring issue.
P2422
• EVAP vent valve failure.
• Wiring issue.
P2431
• Air control solenoid failure.
• Secondary Air System pressure sensor failure.
• Wiring issue.
P2432
• Wiring issue.
P2500
• Alternator failure.
• Battery failure.
• Wiring issue.
P2501
• Battery failure.
• Wiring issue.
P2503
• Battery failure.
• Wiring issue.
P2509
• Powertrain Control Module (PCM) power relay failure.
• Wiring issue.
P250C
• Oil level sensor failure.
• Wiring issue.
P2601
• Coolant Heat Storage (CHS) water pump failure.
• Coolant Heat Storage (CHS) water pump relay.
• Wiring issue.
P2607
• Intake air heater.
• Wiring issue.
P2609
• Wiring issue.
P2610
• An internal PCM problem.
• A problem with the PCM power or ground circuit.
P2614
• Broken tone ring.
• Camshaft Position Sensor (CMP) failure.
• Wiring issue.
P2706
• Wiring issue.
P2711
• Internal transmission failure.
• Transmission solenoid failure.
• Wiring issue.
P2714
• Wiring issue.
P2716
• Wiring issue.
P2723
• Wiring issue.
P2803
• Transmission range sensor failure.
• Wiring issue.
P2806
• Transmission range sensor is out of adjustment.
• Wiring issue.
P2809
• Transmission pressure control solenoid failure.
• Wiring issue.
P2810
• Wiring issue.
P2815
• Wiring issue.
P2A00
• Exhaust leak.
• Wiring issue.
P2A01
• Exhaust leak.
• Wiring issue.
P2A03
• Exhaust leak.
• Wiring issue.
P2A04
• Exhaust leak.
• Wiring issue.
P2BA8
• Faulty NOx Sensors.
• NOx Sensors harness is open or shorted.
• NOx Sensors circuit poor electrical connection.
• Faulty Diesel Particulate Filter (DPF).
P3000
• Fuel level is too low.
• High voltage battery is not sufficiently charged.
P3100
• High voltage powertrain control module failure.
P3400
• Faulty Cylinder Deactivation System/td>.
P3401
• Variable valve timing solenoid failure.
• Wiring issue.
B0081
• Wiring issues.
• Control module problems.
• A problem with the airbag.
C0040
• A faulty wheel speed sensor.
• A problem with the wheel speed sensor circuit.
• Reluctor issues.
• A problem with the ABS module.
U0001
• Reluctor issues.
U0073
• A faulty control module.
• A problem with the CAN bus.
U0100
• A faulty PCM.
• A problem with the control module circuit.
U0107
• A dead battery.
• A faulty TAC module.
• A problem with TAC module circuit.
U0121
• A dead battery.
• A faulty ABS module.
• A problem with ABS module circuit.
P0010
• Wiring issue.
P0011
P0012
P0013
• Wiring issue.
P0014
P0101
P0102
P0113
• Dirty air filter.
P0128
P0135
• Defective PCM.
P0171
P0174
P0200
P0201
P0202
P0203
• Wiring issue.
P0205
• Wiring issue.
P0300
• Vacuum leak(s).
P0301
• Vacuum leak(s).
P0302
• Vacuum leak(s).
P0303
• Vacuum leak(s).
P0304
• Vacuum leak(s).
P0401
P0420
P0430
P0440
• Missing fuel cap.
P0441
• Missing fuel cap.
P0442
P0455
• Missing fuel cap.
P0500
P0501
P0505
P0506
P0507
P0600
P0601
P0602
• Wiring issue.
P0603
P0605
P0700
P0705
P0706
P0720
P0730
P0841
• Wiring issue.
P0842
• Wiring issue.
P0845
• Wiring issue.
P0846
• Wiring issue.
P0847
• Wiring issue.
P0901
P0935
• Wiring issue.
P0942
• Wiring issue.
P0944
• Wiring issue.
P0961
P0A08
• Wiring issue.
• Wiring issue.
• ECU issues.
P0A80
P0B22
P0B24
• Wiring issue.
P0B26
• Wiring issue.
P0B28
• Wiring issue.
P0B30
• Wiring issue.
P0C00
P0C09
P0C11
P0C14
P0C15
P2000
• Intake air leak.
PP2002
• Intake air leak.
P2004
• Wiring issues.
P2006
P2101
• Wiring issue.
P2122
• Wiring issue.
P2135
• Wiring issue.
P2138
• Wiring issue.
P2181
P2210
• Wiring issue.
P2213
• Wiring issue.
P2237
• Exhaust leak.
• Wiring issue.
P2238
• Exhaust leak.
• Wiring issue.
P2251
• Exhaust leak.
• Wiring issue.
P2302
• Wiring issue.
P2303
• Wiring issue.
P2305
• Wiring issue.
P2308
• Wiring issue.
P2310
• Wiring issue.
P2401
• Wiring issue.
P2402
• Wiring issue.
P2422
• Wiring issue.
P2431
• Wiring issue.
P2432
• Wiring issue.
P2500
• Battery failure.
• Wiring issue.
P2501
• Battery failure.
• Wiring issue.
P2503
• Battery failure.
• Wiring issue.
P2509
• Wiring issue.
P250C
• Wiring issue.
P2601
• Wiring issue.
P2607
• Wiring issue.
P2609
• Wiring issue.
P2610
P2614
• Broken tone ring.
• Wiring issue.
P2706
• Wiring issue.
P2711
• Wiring issue.
P2714
• Wiring issue.
P2716
• Wiring issue.
P2723
• Wiring issue.
P2803
• Wiring issue.
P2806
• Wiring issue.
P2809
• Wiring issue.
P2810
• Wiring issue.
P2815
• Wiring issue.
P2A00
• Exhaust leak.
• Wiring issue.
P2A01
• Exhaust leak.
• Wiring issue.
P2A03
• Exhaust leak.
• Wiring issue.
P2A04
• Exhaust leak.
• Wiring issue.
P2BA8
P3000
P3100
P3400
P3401
• Wiring issue.
B0081
• Wiring issues.
C0040
• Reluctor issues.
U0001
• Reluctor issues.
U0073
U0100
• A faulty PCM.
U0107
• A dead battery.
U0121
• A dead battery.
NBCat
close
- Join DateJan 2012
- LocationNewport Beach, California
Liked:2,983 Times in 2,028 Posts
Thank you for taking time to compile this DTC list.
Perhaps one of the forum moderators can add it as a sticky to the X350/X358 forum.
As noted this is a list that was made by mechanics, in a dealership, of the most common failures they were seeing. My bet is that originally it was done to help each other out to diagnose these common failures for quicker turnaround.
I have yet to find a DTC list with every fault possible listed. My car can always come up with ones not in any list, including the official list on this site. It would be great to have one for all, including the hexadecimals that pop up fairly frequently.
Don B
close
- Join DateFeb 2014
- LocationCrossroads of America
Liked:15,275 Times in 7,256 Posts
Hi x350,
Not to rain on your parade, but that is not a Jaguar-specific list of DTC definitions and possible causes. It's a generic list that appears in many places online.
For example, here's the same list on a Porsche dealership website:
https://www.porscheirvine.com/servic...uble-codes.htm
And at a MINI dealership website:
https://www.miniofthewoodlands.com/s...uble-codes.htm
And Bentley:
https://www.bentleynewportbeach.com/...uble-codes.htm
And Hyundai:
https://www.autonationhyundaiohare.c...uble-codes.htm
When working on Jaguars, it is always prudent to first consult the Jaguar factory service documentation, since Jaguar's own definitions and possible causes often differ from generic ones. It certainly doesn't hurt to consult other sources as well, but you may avoid wasted time by starting with Jaguar's recommendations. You can download one of the more complete versions of the X350 DTC Summaries manuals here:
Jaguar X350 DTC Summaries
Cheers,
Don
And Bentley:
And Hyundai:
Cheers,
Don
Cheers,
Don
Very helpful. One thing I've learned though is the frustration when the link goes dead. So I went to http://www.jagrepair.com/DTCforms/X350_P_DTC_OBD_II.pdf and merged it into the generic list. Generic in red. I could not figure out how to upload it as a table, so I converted it to jpgs... 23 of them. Best read on a big-screen desktop PC.Originally Posted by Don B
...When working on Jaguars, it is always prudent to first consult the Jaguar factory service documentation, since Jaguar's own definitions and possible causes often differ from generic ones. It certainly doesn't hurt to consult other sources as well, but you may avoid wasted time by starting with Jaguar's recommendations. You can download one of the more complete versions of the X350 DTC Summaries manuals here:
Cheers,
Don
It's too bad this forum cannot also have a Wikipedia-like application so we can build a knowledge base with the latest version on the main page, and previous contributions and talk on secondary pages. The problem with a forum is knowledge mixed with comments mixed with earlier versions.
