Obd sensors
Old Apr 17, 2021 | 08:11 PM
Driftinluke's Avatar
Default Obd sensors
It seems like it takes a long time I me for all the sensors to reset. I have two that show incomplete after 400 miles and following a couple prescribed drive cycles...the comprehensive monitor and egr monitor. Meanwhile, I have a persistent code and mil on because of engine temperature staying too low. I guess I need a new thermostat. I see partsgeek has the assembly for an oem equivalent, but im wondering of there is a metal upgrade. I'm also hoping that the code will clear itself after the thermostat is working properly and it restarts and hears up to temperature a few times. If I can get it inspected I'll be happy to drive it and get everything sorted out. My mechanic is on vacation for about a week so if all goes well I can get my sticker then.
Old Apr 17, 2021 | 08:49 PM
motorcarman's Avatar
If certain parameters are required to set readiness, engine temp is probably one of them.
Engine temp not reaching specified range will probably prohibit completion of some?
Old Apr 19, 2021 | 09:24 AM
JagV8's Avatar
I suspect by sensors you mean OBD monitors. Expecting them to set (not clear) with any fault flagged is optimistic...
Old Apr 19, 2021 | 12:57 PM
Wingrider's Avatar
Seems that the 04's are often a real pain for the comprehensive components to clear.
Mine has not cleared in over a year now, the E G R valve was slower than the 07's,but cleared eventually.
Still passes smog test, with one not clear, it runs well, so life is great
Old Apr 19, 2021 | 01:07 PM
Default Will the codes self clear when the problem is fixed?
I've ordered a replacement thermostat assembly, which should arrive in a couple of days. The only code it's showing at last check is p0128, but the check engine light is on. Will the code clear and the light go off after a few restarts with the coolant heating up to temperature as it should, or will I have to clear the codes and go through resetting all the sensors again?
Old Apr 19, 2021 | 01:33 PM
Wingrider's Avatar
Just guessing that it should clear on its own, after it warms up, the way it should.
Old Apr 19, 2021 | 05:06 PM
JagV8's Avatar
After 4 warm ups with no faults the MIL should go off.
Mike Beda
Jun 5, 2019 06:58 PM
micmee1
Jan 12, 2018 08:48 AM
jackra_1
17
Aug 1, 2017 07:49 AM
Aerojag
Dec 30, 2015 06:43 AM
MARK
Jan 29, 2012 09:54 AM
