Padding Hanging Down From Bonnet (Driver's Side)
Old May 7, 2022 | 07:48 PM
Rickkk's Avatar
Default Padding Hanging Down From Bonnet (Driver's Side)
A few days ago, I noticed the padding from the bonnet hanging down on the drivers side of my 2005 Jaguar XJ8L. Actually, I'm not sure what kind of adhesive I could use to secure that padding. Any tips or suggestions? Thanks.
Old May 7, 2022 | 10:09 PM
Luke2004xjr's Avatar
This is your hood Insulation, and i is held up with clips, no glue that I know of. Hope this helps.
Old May 8, 2022 | 07:55 AM
Rickkk's Avatar
No clips that I could see on the part of the insulation that's hanging down.
Old May 8, 2022 | 09:16 AM
Eric-in-Texas's Avatar
when mine did that, I just removed the whole thing. I looked for a replacement, but those are a bit hard to find. I hope it won't ruin the finish on the hood, but it had lost all its rigidity, and reattaching it seemed unlikely.
I still have it in my hope chest in case someone knows how to restore it.
Old May 8, 2022 | 11:02 AM
scooterforever's Avatar
There are various threads on cut-to-fit replacements. It's what I did, in fact if you search under my user name I think I wrote about what I used. The stock liner begins to break down over time.
Old May 8, 2022 | 01:33 PM
abonano's Avatar
Get large auto washers (like 1" to 1.5" in diameter) paint them black and use very short self tapping sheet metal screws.
Go into a section, where the hood metal is recessed downward and tap into that section.
I think with your situation 1 or 2 placed strategically will suffice.
Old May 8, 2022 | 05:41 PM
Rickkk's Avatar
Thanks for the tips and suggestions. Yeah, I'll see what I can do.
Old May 8, 2022 | 10:28 PM
Right above where it is hanging, it is attached/ How is it attached? When I loo up the parts for the car, it show clips for it. Here is a picture. It shows some round and rectangle clips. Hope this helps. Be kind and think of others
of mine
Old May 10, 2022 | 10:21 AM
Eric's XJR's Avatar
Default Same problem used Lexel
I glued the edges of mine down with Lexel right after I bought the car and haven't had any problems since.
If you haven't used Lexel before, it is applied with a caulking gun and works great for demanding glue jobs.
Old May 10, 2022 | 11:13 AM
Rickkk's Avatar
I think what I might do is to clean the affected area, use a layer of duct tape to hold the end of the insulation down, and then apply some Testors Flat Black spray paint over the duct tape. Actually, it might just work.
Old May 10, 2022 | 01:59 PM
quattrofrank's Avatar
Just remove the thing
You will improve sound, cooling and reduce weight.
In addition you remove a fire hazard if you were to leak/spray oil on it
Old May 10, 2022 | 02:50 PM
ChrisMills's Avatar
The more Gold showing the better. We Goldies must stick together.
Seriously, that liner is shot. Dunno if this is still available but appears to be in Michigan.
Terrys Jaguar Parts: INSULATION, BONNET XJ 2003 - 2009
Old May 11, 2022 | 12:35 AM
Terrific's Avatar
3M or other spray trim adhesive to glue back into place Don' be afraid to remove the large headed plastic retainers as necessary get back into position. Retainers are readily available on line or at part stores. Put additionals where areas are soft. Put extras only in double panel areas, Be very careful drilling for extras. Be attentive around the engine air intake at core support, if it is sagged it will block air flow and cause poor performance and mileage. Or you could remove it if beyond repair.. There are a number of adhesive backed sound deadners available that can be cut and fitted on the bare hood areas to keep heat from damaging paint and give a finished look.
Old May 13, 2022 | 10:40 AM
Rickkk's Avatar
Update: Well, the duct tape idea didn't pan out last Wednesday. As per one member's suggestion, I did order a can of 3M Super 77 Multipurpose Spray Adhesive.. When I do get a chance of trying the spray adhesive out, I'll post another update.
Old May 21, 2022 | 04:53 PM
Rickkk's Avatar
Update: Well, I applied some 3M Super 77 Multipurpose Spray Adhesive on the hood insulation of my 2005 Jaguar XJ8L today, and I would describe the results as mixed. Actually, this appeared to be a VERY temporary fix as I really didn't have a lot of faith in that spray adhesive to securely bond the insulation back onto the underside of the bonnet. If the hood insulation should begin to separate again, I might simply try applying some clear silicone as I believe that would provide better adhesion.
Old May 23, 2022 | 04:12 PM
Rickkk's Avatar
Update: I decided to complement the hood insulation repair today by injecting some clear silicone 388 in a few spots so as to beef up the repair. Well, I think that should hold up for the time being.
666jag
Oct 14, 2021 11:53 PM
Winalot
Aug 16, 2021 02:10 PM
stuart goodwin
General Tech Help
Dec 21, 2016 07:28 AM
madjaq
Jul 21, 2016 08:52 AM
buildingonfire
Mar 3, 2016 03:35 PM
