Problem with cooling fan
Old Feb 3, 2010 | 04:03 PM
robr's Avatar
Default Problem with cooling fan
I had a small leak in the reservoir tank that I fixed on my '07 XJ8. Now the cooling fan runs almost all of the time. Could it be that I now have the wrong mixture of coolant to water since I have topped off the reservoir tank with water on a few occasions or maybe a bad thermostat? Any suggestions would be greatly appreciated.
Old Feb 4, 2010 | 04:55 AM
Real_Tech's Avatar
Are you sure it is full? How many miles has it been driven since the tank was replaced? It is possible that if it overheated there may be damage to the t-stat. An air pocket could cause this problem, coolant mixture could not.
dsnyder586
Dec 29, 2024 07:39 PM
mbergen
Oct 23, 2019 10:26 PM
Jjscruggs1
Aug 2, 2017 04:40 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
