question
Old Feb 22, 2009 | 04:53 PM
rusbel's Avatar
Default question
I have a new '08 XJR with under 1000 miles on it now...I do a lot of highway driving. The other day after pulling off the highway i got out of the car and noticed a ticking noise...almost like soft valvetrain noise...I turned it if and started it back up and the noise was gone. Not sure if this is normal...Anyone heard of this before? I don't want to take it to the dealer if i don't have to. Thanks!
Old Feb 22, 2009 | 07:16 PM
Real_Tech's Avatar
If the sound seemed to be coming from the left side in front of the drivers(lhd) door it was probably the canister purge valve doing its job. The valve is mounted behind the wheel arch liner at the rear of the wheel well. It's covered with a sound absorbing liner but some valves are louder than others.
Old Feb 22, 2009 | 07:40 PM
rusbel's Avatar
It does sound like it's coming from the left side ...thanks! Would you expect for it to go away once the car is turned off and then back on again? I am new to Jaguar and none of my previous cars did this...thanks again!
Old Feb 22, 2009 | 09:30 PM
panels's Avatar
Is this the Sound you hear?
http://www.youtube.com/watch?v=8VNuCfv1Uiw
Tom
Old Feb 23, 2009 | 07:58 AM
rusbel's Avatar
Question
No...I can't hear it from the inside at all...mine is more like soft ticking. It happens only when the car is driven for a while and goes away if you turn it off and start it back up...????
redgear
Sep 18, 2015 10:05 AM
SeanU
Sep 18, 2015 08:09 AM
kamiar
Sep 17, 2015 06:30 PM
pnwrs2000
Sep 17, 2015 04:04 PM
DustysSon
Sep 13, 2015 04:17 AM
