Removing ABS wiring connector
Old May 5, 2021 | 08:05 PM
pragmatic's Avatar
Default Removing ABS wiring connector
I'm still troubleshooting a DSC problem, code C1285. I do not have voltage at the booster solenoid (pin 4) and need to disconnect the wiring connector from the ABS module to continue trouble shooting this issue. I flipped open the cover but can't see any clips holding the connector onto the module. Haven't been able to find how to do it in the manual or other posts. Any help is appreciated.
Old May 10, 2021 | 07:27 AM
OldKarz's Avatar
Keep opening the cover further. It has cam action that pushes the connector off.
Old May 10, 2021 | 11:55 AM
pragmatic's Avatar
Thanks I see that. Someone been there before and broke the two plastic tabs connecting the cover to the rest of the mechanism. I slowly worked the broken side plates up with a vice grip and an pick. I plan on spraying a little silicone lubricant on the sliders so I'll be able to remove it more easily next time. Once I get time I'll summarize the issues/failures and repairs for my car.
alanroberts50
Apr 10, 2021 04:09 PM
ryejag
Jun 24, 2019 10:52 PM
johnking
Aug 15, 2018 02:58 AM
mrobinson
Nov 16, 2016 10:09 AM
AlZee
Dec 17, 2011 08:16 AM
