Removing ABS wiring connector
I'm still troubleshooting a DSC problem, code C1285. I do not have voltage at the booster solenoid (pin 4) and need to disconnect the wiring connector from the ABS module to continue trouble shooting this issue. I flipped open the cover but can't see any clips holding the connector onto the module. Haven't been able to find how to do it in the manual or other posts. Any help is appreciated.
Thanks I see that. Someone been there before and broke the two plastic tabs connecting the cover to the rest of the mechanism. I slowly worked the broken side plates up with a vice grip and an pick. I plan on spraying a little silicone lubricant on the sliders so I'll be able to remove it more easily next time. Once I get time I'll summarize the issues/failures and repairs for my car.
johnking
Aug 15, 2018 02:58 AM
