Shudder during braking
Old Sep 14, 2019 | 02:52 PM
maybewill's Avatar
Default Shudder during braking
At speeds above 40mph I'm getting shudder. Feels like it's both front and rear. Garage says replace the rotors. Is that right?
Old Sep 14, 2019 | 06:12 PM
meirion1's Avatar
If you only get the shudder when braking and pulsing via the brake pedal then probably the rotors.
Try just replacing the fronts first.
Old Sep 15, 2019 | 12:39 PM
maybewill's Avatar
Hi -thanks for the tip
Old Sep 15, 2019 | 10:10 PM
Don B's Avatar
Hi maybewill,
If you feel a shimmy in the steering wheel, then one or both front rotors is warped. As meirion1 suggested, replace the fronts first and see if that cures all the pulsation and shimmy.
If you feel pulsation in the brake pedal but no shimmy in the steering wheel, it's probably one or both rear rotors.
Braking from higher speeds heats the rotors to higher temperatures, which exacerbates any rotor warpage.
If you feel a shudder at speeds above 40 mph even when you are not braking, suspect a problem with wheel balance or tire damage.
Cheers,
Don
Old Sep 16, 2019 | 03:34 AM
JagV8's Avatar
Check no caliper piston is sticking, as then you get uneven braking with that feeling.
Old Sep 17, 2019 | 09:32 PM
Panelhead's Avatar
If you only feel above 40 mph it may be the rotors are not warped very much. Depending on mileage on rotors I would have them turned. Here that is about 50.00.
If high mileage, over 50k on rotors I would just replace. Found mine on Rock Auto, paid about 120.00 for AC Delco. Looked and they have gone up. 120.00 will get a set of Raybestos. 150.00 for Bendix. Not sure if one is better than the other.
I would stick with known names.
AlexJag
Mar 19, 2019 08:28 AM
swayne
Aug 8, 2018 01:35 PM
Fastlane'scat
Feb 9, 2014 06:27 PM
DevSpider
Oct 15, 2013 08:07 PM
flyrr100
Jul 29, 2012 09:14 PM
