A Silly but Handy Discovery
Old Jan 14, 2014 | 11:42 PM
staggerwing17's Avatar
Default A Silly but Handy Discovery
Due to an air leak in the suspension system, I have had the spare tire and all other items out of the trunk. Since we got the car several months ago, I always wondered why the little handle that one pulls to open the access door for the spare compartment was located in such a dumb place.
Well, tonight, this dumb owner figured out that the handle also works as a hook to hold the access cover open. Simply pull the handle out as far as it will go, open the spare tire compartment as far as it will go and hook the edge of the handle over the the front of the trunk compartment rubber weather seal. Really easy! I did not see this in the manual which I did read but as is so often the case, it is user error! 2 pics are at the links below: one is of the handle in the access door and the other is of the deployed handle as shot from near the rear window where it meets the body.
Image of closed handle on floor of trunk:
Attached Thumbnails A Silly but Handy Discovery-imag1131.jpg   A Silly but Handy Discovery-imag1130.jpg
Last edited by staggerwing17; Jan 17, 2014 at 03:11 PM. Reason: Trying to add pics.
Old Jan 15, 2014 | 05:00 AM
paydase's Avatar
Pics?
Old Jan 15, 2014 | 09:50 AM
BlackX300VDP's Avatar
That's a neat little trick there. I was using them all the time during PDI's and other trunk concerns. Problem is that it usually slips off too. Gives you a little thunk on your head if your working in the spare tire well. haha.
Old Jan 16, 2014 | 08:29 AM
RCSnyder's Avatar
People can say what they want about quitting early to have a pint, but many a creative thought starts under the influence. Very little on these cars is done without good reason.
Old Jan 16, 2014 | 03:30 PM
reyesl's Avatar
I assumed they were designed to be used in that way..
Old Jan 17, 2014 | 03:15 PM
Originally Posted by paydase
Pics?
Hey paydase! I apologize for the images not appearing. I have re-added them and I see them on the forum site. Let me know if youo can now see them. But this is the same with the original post - that is, I clicked insert image, entered the url, the image(s) appeared but now they do not. If you have any tips on getting images into posts, let me know - sorry again for the trouble.
Old Jan 17, 2014 | 03:20 PM
What I could really use is something to stop me from hitting the back of my head on the trunk latch. You would think I would learn after the first few painful reminders but it seems I do not learn particularly quickly!
Old Jan 17, 2014 | 09:10 PM
cjp's Avatar
cjp
Being "folically challenged" myself, I share your pain, literally.
A hat helps! Not helpful?
Chris
Old Jan 19, 2014 | 12:16 AM
dsetter's Avatar
My trunk handle works to hold it up, I do not have the same separate hook. Some things are just different between years for some reason. Same function but different form.
Old Jan 19, 2014 | 05:25 PM
paydase's Avatar
Pics appear now, thanks.
As dsetter, I do not have this kind of handle on my car...
Serge
Old Jan 19, 2014 | 08:31 PM
Gazoo2's Avatar
This little trick is actually covered in your owner's manual.
Old Jan 20, 2014 | 06:31 AM
reyesl's Avatar
Very true:
Old Feb 8, 2014 | 05:07 PM
xylorex's Avatar
I can't ever bring myself to use it, i'm always worried that it will damage the weatherstrip...
Old Feb 9, 2014 | 10:01 AM
Partick the Cat's Avatar
I figured that one out fairly early, but it's the sort of thing that can pass you by quite easily.
For years I wondered what the purple dot and thumb push were for on the bonnet (hood) strut on my old Mercedes - then I saw in a workshop that you can unclip the bottom of the strut and raise the bonnet and lock it vertical (the purple dot is the vertical catch release).
And all those bumped heads while changing the oil filter ...
duecedriver
Dec 25, 2015 11:47 AM
picard
Oct 12, 2015 11:56 AM
ayavner
Sep 14, 2015 07:41 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
Jagstype32
Jaguarforums Merchandise
Sep 7, 2015 03:08 AM
