Sloppy Ignition Switch: Normal???
Old Apr 19, 2016 | 03:24 AM
hisport's Avatar
Cool Sloppy Ignition Switch: Normal???
My '07 XJR Ignition Switch feels really weird.
After inserting key, it takes a quarter turn (~ 40 degrees) of slop before encountering first sw position, then another large turn against a strong spring to engage starter
Everyone who has driven the car has asked about it
Is this normal, or is something amiss?
Old Apr 19, 2016 | 04:32 PM
mastersid's Avatar
hisport , exactly the same as my 07 XJ8L
I don't know that it's normal , but certainly has caused no problems ,........ yet
Cheers ,
Old Apr 20, 2016 | 02:29 AM
woox4's Avatar
Mines the same...
Old Apr 26, 2016 | 03:16 PM
ayavner's Avatar
same, lots of wiggle
Old Apr 30, 2016 | 04:59 PM
abonano's Avatar
Ignition barrel springs probably wearing down...
Old Jun 26, 2016 | 01:05 AM
06-XJR's Avatar
I just bought my 06 XJR today. It's ignition switch is well used too I guess, I can't believe how sloppy it is. I'm wondering if I should have the dealer replace it. It works but I am slightly concerned.
Honestly that was my biggest concern with the car. I inspected quite a few things on the car and that was the only abnormal thing that I noticed. It kinda bugs me though...
Old Jun 26, 2016 | 07:23 AM
lcmjaguar's Avatar
This is normal due to its design. The ignition switch has to pull a long cable to where the ignition module is. This set up is designed to remove the ability to hotwire the car at the ignition switch.
Old Jun 26, 2016 | 08:14 AM
ryejag's Avatar
I have I suspect a related issue. If the switch is hit from the bottom when the car is running the car will turn off. Never a problem otherwise. Noticed this one time when I hit a bump and my knee hit the bottom of the key. I suspect its switch wear but reluctant to change and have to deal with reprograming the electronics and or having multiple sets of keys one of the ignition and another for the doors if needed
RyeJag
Kief
Apr 26, 2016 10:29 AM
Terry007
Apr 22, 2016 05:04 PM
jaguarVP96
Apr 22, 2016 02:21 AM
Johncy2000
Apr 21, 2016 12:36 PM
machimba
Apr 20, 2016 02:21 PM
