Speech Recognition Inop
Old Jan 1, 2012 | 06:57 PM
MK 82's Avatar
Banned
Default Speech Recognition Inop
No matter what I do or say it shows "speech not detected." Any ideas where to start.
I hadn't used it in years. This evening I installed the new 2011-2012 Nav DVD. It went thru some kind of software update. The map seems to work fine but the speech is inop for everything-not just the Nav. Could the two be related?
Old Jan 2, 2012 | 01:58 PM
jahummer's Avatar
Let me know what you find out, I was going to buy one tomorrow.
Old Jan 2, 2012 | 02:37 PM
MK 82's Avatar
Banned
I read a thread about Jag deactivating Jaguar Voice on some 2011 models. When I put this new disk in it went thru a software update. Now my Jag Voice doesn't hear me.
I have a msg in to the guy I got the disk from but no answer.
Old Jan 2, 2012 | 04:32 PM
MK 82's Avatar
Banned
My source knows nothing about it. The DVD is a copy.
Old Jan 2, 2012 | 05:15 PM
jahummer's Avatar
I asked the dealer about it but they haven't received their shipment of disks yet. They did mention that Jaguar voice has had issues, although mine has almost always worked save when everything stops working.
Old Jan 2, 2012 | 05:17 PM
u102768's Avatar
If your old nav disc has the firmware on (LOADING.KWI) you can force it to reload that to make sure it isn't anything to do with the firmware from the new disc.
Put the old disc in the nav unit, go in to the setup menu on the touch screen (hold down the phone button and menu) press 917 then enter then use the software update button to force the nav unit to read the firmware.
Jaguar don't recommended downgrading firmware but I have flipped my unit backwards and forwards a few times without issues.
Old Jan 2, 2012 | 05:22 PM
jahummer's Avatar
That's right, I forgot about that.
Old Jan 2, 2012 | 08:02 PM
MK 82's Avatar
Banned
Tried the S/W Update but the button is grayed out.
Old Jan 2, 2012 | 08:21 PM
jahummer's Avatar
That is because you need the code that allows you to modify the system: 1971
You should get some sort of prompt warning to confirm what you are about to do.
Old Jan 2, 2012 | 09:04 PM
u102768's Avatar
917 works fine on mine although the software update button is not greyed out even if there is no DVD in the slot.
On mine 1971 mainly gives me more options and a cancel button so that you can get back to the standard menu.
One other thing I noticed is that with 917 it prompts you to insert a firmware DVD whereas with 1971 it detects that there is no DVD and offers to boot from 'cf' instead.
Old Jan 3, 2012 | 08:27 PM
MK 82's Avatar
Banned
I only tried 917 because that is all I knew. I will try 1971 tomorrow.
Old Jan 4, 2012 | 05:12 PM
MK 82's Avatar
Banned
I couldn't get it to go back. Actually lost the screen for awhile with the 50 and 51 error. Finally got the screen back. Guess Jaguar Voice is gone.
Old Jan 4, 2012 | 05:32 PM
jahummer's Avatar
Maybe a hard reset or WDS can reactivate it?
Johnken
Sep 22, 2015 03:53 PM
TheWarlock
Sep 7, 2015 09:30 PM
Translator
Sep 27, 2010 12:33 PM
