starting problems
Old Jul 21, 2007 | 12:56 AM
badmojo's Avatar
Default RE: starting problems
The air ride system needs the engine running to drive the pump. Does the engine pop or fire at all?
Old Jul 23, 2007 | 09:30 AM
badmojo's Avatar
I would call a dealer and talk to a servive guy before bringing it in. It might be a simple problem. It's not the ignition cutoff switch is it?
Old Jul 24, 2007 | 09:44 AM
badmojo's Avatar
The cutoff switch is usually on the drivers side down on the floor far left and up slightly. It looks like a small knob or button. if you find it try pulling up on it. even if it's already up I would try pushing it down and pulling it up again. It's very easy to accidently hit this switch and it kills the whole car. I tripped mine just putting in floor mats and it drove me nuts trying to find the problem.
Old Jul 24, 2007 | 10:18 AM
93xj6's Avatar
Having cars sit for that long can be very bad for everything, that's why it's always recomended to run it on the highway a few times a month.
Hopefully it won't come down to getting it towed into the dealer and having them do everything possible, including giving you a huge bill
Old Jul 27, 2007 | 09:15 PM
I'm sure I read / heard somewhere, that the batteries in the keyfobsdieand if you don't replace them in time, they will not start the car? Loses programming or something along those lines
Jim
Old Jul 28, 2007 | 05:06 PM
badmojo's Avatar
The valet key has no fob or battery so I don't think that's it.
Old Aug 17, 2007 | 06:12 PM
jag_genius's Avatar
if everythings starting whise is ok ... 2004 xj did have a hydraulic locking problem.. head bolts wud come loose and fill the cylinders.. rare tho... butr possible... coolant low?
JarodL
Mar 7, 2024 01:39 AM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
laserguy
Sep 3, 2015 02:02 PM
