Steering column lock problem
Old Sep 9, 2025 | 09:14 AM
twix221's Avatar
Default Steering column lock problem
Hi guys, today I recalibrated my air suspensions with SDD. To do this, I first cleared the fault codes, then recalibrated. The suspensions are working. I ran the engine for 5 minutes to check them. I turned off the engine and locked the car. An hour later, my car won't start. I have a message on the dashboard saying "the steering column is locked." When I put the key in the ignition switch, I hear the steering unlock (I can turn the wheel without any problem). Question: Can I troubleshoot my car with SDD, or do I have to replace the ESL (I have to bring my desktop PC and monitor into my garage)?
I noticed that if I unlock the car with the key, the alarm goes off. With the remote control, I no longer have this problem.
Thanks. Best regards,
Marc
Old Sep 9, 2025 | 12:22 PM
Wingrider's Avatar
Were you charging the battery, with the proper type of charger, while using the SDD software???
That could explain the flat battery issue
Old Sep 9, 2025 | 12:44 PM
twix221's Avatar
Yes, I'll do that tomorrow. I ran my diagnostics. It gives me error U2195 = SCP (J1850) invalid data from the steering column lock control module. I just remember that my steering is unlocked, I have a message that says the column is locked and it prevents me from starting.
Old Sep 9, 2025 | 02:35 PM
Jacuar's Avatar
Sorry about your troubles. Did you try moving the transmission gear selector around to make sure it was fully seated in the park position? Also, does the selector lock and unlock as normal?
Old Sep 9, 2025 | 08:28 PM
xalty's Avatar
unplug cluster and program cluster as new. when it asks you if it has a column lock say no
Aref
Oct 18, 2024 05:38 AM
DOCKERS
25
Mar 18, 2024 09:44 AM
Aarcuda
Oct 20, 2020 08:51 PM
mhamilton
Feb 5, 2019 09:51 PM
u102768
Aug 20, 2011 04:44 PM
