Help needed diagnosing DSC/ABS fault. Too many codes!
Hi all.
on my 2003 XJ8
I have abs and dsc lights on, also ‘dsc inoperative’ message. These are the fault codes as read by a snap on diagnostic. Would appreciate some help on this as there are so many codes its hard to know where to start!C1165 wheel speed sensor rear right input circuit fail
C1175 wheel speed sensor rear left input circuit fail
C1280 yaw rate sensor signal failure
C2778 sensor power supply failure
P1260 security input
P1582 flight recorder data is stored
U1027 SCP(J1850) invalid or missing data engine rpm
U1040 SCP(J1850) invalid or missing data vehicle speed
U1058 SCP(J1850) invalid or missing data vehicle transmission
5200H/20992 undocumented code
on my 2003 XJ8
mesaboogieman (02-09-2020)
Thanks for that.
Seems strange that both rear sensors and the yaw rate sensor could all be faulty but I’ll probably try replacing them all for starters. No info from the engine Rpm, vehicle speed and gearbox is a bit of a worry, I’m trying to think of a common fault that would cause all three
Thanks for that.
Would have thought you would flag a CATS System or Suspension fault if those codes are all still present?
Some of the codes could be caused by a battery 'dip' at startup?
It seems the previous owner was messing about with the JLR SDD software when the battery ran down resulting in at least three different control modules being corrupted. Now they wont talk to the diagnostic so theres no way of resetting them.
I only got it as a cheap project to tinker with, but its going to take way too much time to sort out so unfortunately its got to be sold as is.
