Supercharger belt
Old Mar 23, 2025 | 02:09 PM
quattrofrank's Avatar
Default Supercharger belt
Hi
I was planned to change out my supercharger belt on my 05 super v8. However it does not seem to be available anymore. Sng sold a kit to convert it to be able to use another belt, but this is also no longer available.
So were to get a new drive belt for the supercharger?
Seems there was a change at chassinumber : H17573
Old Mar 23, 2025 | 02:37 PM
Thomas-S.'s Avatar
Hi Frank,
the converion kit is basically a must for all supercharged cars up to VIN H17572, as the original type of belt is not available anymore. The original type of belt was ribbed only on one side, whereas the new type is ribbed on both sides.
You can ylso buy the parts needed separately, if you cannot find the complete kit:
I know of the following source for the complete kit, but it is in Germany:
https://www.jaguar-shop.com/epages/6...ducts%2FHR2234
Best regards,
Thomas
Old Mar 23, 2025 | 02:39 PM
Pete M's Avatar
Hi quattrofrank,
I've just had a look at Jaguar Rover Classic Parts and they show the belt as available. They are usually good at listing unavailable parts correctly, so give them a try.
Supercharger belt
Supercharger belt
Pete M
P.S. Hi Thomas, Greetings from NZ. You beat me to it by seconds! You are right, I forgot the change, as my car is H25812 so is already modified.
I wonder, can you just swap the idler and tensioner pulleys over?
Old Mar 23, 2025 | 02:46 PM
Thomas-S.'s Avatar
Hi Pete,
that is the new type belt that will not fit the 2005 SV8 without the other parts. The belt for VINs up to H17573 is not available anymore.
Best regards,
Thomas
Old Mar 23, 2025 | 03:01 PM
Pete M's Avatar
Originally Posted by Thomas-S.
Hi Pete,
Best regards,
Thomas
Hi Thomas,
I replied too quickly and missed that the OP had a 2005 car.
I looked at Gates and they do a belt for that car.
Gates Supercharger belt
It can bee seen that it is only grooved on one side, so is the correct type for 2005, as shown above.
Belt is only grooved on one side
Pete M
Old Mar 23, 2025 | 03:04 PM
thank you, I think its best to order this soon before it will be sold out. My belt has 20years and 100k km on it so probably wise to do so.
Old Mar 23, 2025 | 03:10 PM
Thomas-S.'s Avatar
I did the conversion soon after buying my SV8, at the time it was 15 years old and had 175k km. The price for the kit at the time was less than 300 EUR.
Best regards,
Thomas
Old Mar 23, 2025 | 03:16 PM
I did see someone mention that the swap/change in belt design was to reduce noise, did you notice any difference? I dont want to loose any supercharger noise
Old Mar 23, 2025 | 03:34 PM
Thomas-S.'s Avatar
Sorry, I basically started driving my car after I did the conversion, so I cannot really make a comparison.
But: the supercharger is is present enought for my taste, and, if they say that the design change was made to reduce noise, I presume that they mean reducing the noise made by the belt itself. Consequently, my logic would be that the supercharger noise itself should be more present than before the conversion.
Best regards,
Thomas
Old Mar 23, 2025 | 04:33 PM
Pete M's Avatar
You are right about the noise, but the problem was that on cold starts in cold weather the belt sometimes made a disconcerting chirping noise.
TSB XJ100-02 dated 05/04 was issued, but later the modified parts as detailed by Thomas above were incorporated into production. The kit was made available to modify existing cars to the new standard. Not every car had the problem, so it was not elevated to the status of a recall.
Pete M
Old Mar 26, 2025 | 11:33 AM
JoeDredd's Avatar
So you have the belt that is ribbed on only one side. Supercharger belt by continental is 8K1325 It took me ages to find this part number as Jaguar was NLA when I bought my car 8 years ago.
Old Mar 26, 2025 | 11:36 AM
JoeDredd's Avatar
Just checked and it looks like it is still available.
Old Mar 27, 2025 | 10:49 AM
xalty's Avatar
8PK1320
6303-2RS big idler pulley bearing sometimes they need green loctite if the press fit is loose
6203-2RS little bearing in the tensioner pulley
Old Mar 27, 2025 | 11:37 AM
so there is two options if using old style belt?
Continental 8K1325
Bando 8PK1320
Old Mar 27, 2025 | 02:27 PM
Pete M's Avatar
Continental 8K1325
Bando 8PK1320
Hi quattrofrank,
Also the Gates K080522 in my post above
Pete M
Old Mar 27, 2025 | 02:38 PM
The partsnumber in your original post did not show up on my screen due to some strange formatting.
Thats great news, so we actually have 3 to choose from
I did look for the continental one, found on ebay but the picture showed a production date of 2014 for the belt, would think its better to get something a little fresher
Aarcuda
23
Sep 17, 2024 05:39 PM
Dave Redline
Mar 27, 2021 09:21 PM
oldtvman
May 12, 2015 12:24 PM
David_h
May 11, 2014 09:29 PM
