Too Rich on Restart
Old Jul 27, 2025 | 04:03 PM
JayChicago's Avatar
Thanks for the help, Mark and xalty.
I do have power at F14. I will check to see if there is continuous power at the purge valve. If not, where can I find that relay R9?
Then I will see if the other wire in the purge valve connector goes to earth. If continuous to earth, I think that indicates a failure at the ECM cuz should only go to earth when the ECM commands. If no earth indicated, doesn't tell me anything,
I do want to look at the NAS "Evap Canister Close Valve". Can you tell me where on the vehicle it is, what it looks like? Is that the same as item 1 shown in post #16 above?
Old Jul 27, 2025 | 08:51 PM
h2o2steam's Avatar
This thread might help you with descriptio of issues and post #9 has picture.
https://www.jaguarforums.com/forum/x...nister-261507/
Sounds like it is incorporated in the charcoal filter assembly and not a separate part and the filter assembly is no longer available new.
It is located above the differential, so likely difficult to get to (haven't been into that area myself yet.
sidescrollin
Dec 15, 2017 09:02 PM
dtony
Apr 28, 2017 12:54 AM
Sarc
Nov 22, 2014 11:02 AM
wagonerkl
Oct 6, 2012 01:01 AM
