Tranny issue on first only
Old Feb 11, 2014 | 01:35 PM
etaent's Avatar
Exclamation Tranny issue on first only
Hey guys, so my 2004 xj8 USA model with 135000 miles runs like new, with the exception of the tranny when I am in first shifting to second gear. The car always shifts into second and the remaining gears without slipping or what not. The only issue is that when I am pulling out of first, if I gas more than 2000 rpms or so, it will shift into second hard and almost pull back a bit before it shifts. If I pull out in first gear softly below 2000 rpms it will shift into second just fine without that happening. Any ideas? Hope its not a major issue!
Old Feb 11, 2014 | 07:24 PM
Gazoo2's Avatar
My 2005 does the same thing - leaves the line firmly then kind of eases up a bit when shifting into 2nd. It almost feels like the traction control cutting in, but it does this even when it's switched off. It's quite subtle but I can notice it. All other trans functions are quite normal.
Old Feb 11, 2014 | 09:10 PM
gmcgann's Avatar
Mine did the same thing. I cleared the transmission adaptations and it went away.
Old Feb 11, 2014 | 11:40 PM
etaent's Avatar
So how would I go about doing that?
Old Feb 12, 2014 | 08:36 AM
gmcgann's Avatar
You need WDS/IDS/SDD. The dealer can do it and also reflash the TCM for about an hour of shop time. I cleared mine to see if it fixed the problem, then a couple of months later I did the pan/filter/fluid change, cleared them again, and reflashed the TCM. The transmission shifts perfectly now.
Old Feb 12, 2014 | 11:47 AM
Lagonia's Avatar
Wanted to confirm as well that clearing the TCM adaptations and re-flashing the TCM resolved an identical problem. Had it done at an independent Jaguar outfit. About 100 bucks.
Old Feb 12, 2014 | 07:23 PM
Gazoo2's Avatar
That is good news, I will arrange to get this done. Thanks guys.
Old Feb 13, 2014 | 09:42 AM
etaent's Avatar
Thanks for the reply! I'll be sure to get this taken care of then once the weather gets nicer here in NYC and I am able to change the transmission fluid pan/filter and then bring it to the dealer. For now I'll just have to drive slowly out if first gear!
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
tomsjag
Jun 10, 2023 10:02 AM
neruda
Oct 18, 2015 01:19 PM
ahunt4
Sep 14, 2015 08:17 PM
