Transmission problem 2005 XJ8L
Old Oct 14, 2024 | 10:53 PM
o gary's Avatar
Default Transmission problem 2005 XJ8L
Suddennly, upon stopping after a short drive, my engine began to stutter and try to stall when put into ger to move either forward or backward. Has anyone have any thoughts about the problem is? Expert transmission shop hasn't been able to determine the cause.
Old Oct 15, 2024 | 03:03 PM
motorcarman's Avatar
Torque converter 'lock-up' fault/failure?
Should be some DTCs in the TCM?
Old Oct 15, 2024 | 05:05 PM
o gary's Avatar
My first thought was torque converter lock up. It's at a trans. repair shop now, waiting to see what the problem is.
Old Oct 16, 2024 | 11:25 AM
Thermite's Avatar
ANY time .. that "codes" .. of some kind.. are 'expected' - off the back of a VERY obvious fault.. but there are NO CODES at all?
Prime suspect is 'electrical'. eg: intermittent... ground, control bus connection, circuit trace or joint fail on a sensor or controller that is only periodically/randomly/temporarily 'blinding' the snoopervisory logic to what has been happening.
Easy to say.
Harder to locate. Tedious, even.
ESPECIALLY as the intermittent nature may lead a repairman to believe it "resolved" off the back of other work, or mere manipulation... when it is not 'fixed'.. just on holiday...... and will return.
Old Oct 16, 2024 | 12:49 PM
o gary's Avatar
Thanks. You are probably right.
ronrowand
Aug 26, 2024 10:34 AM
3labsdaddy
Mar 20, 2019 04:19 PM
w4tja
Jun 29, 2014 09:16 PM
2005 XJ8L
Apr 7, 2011 12:21 AM
