trickle charger connection points in engine bay?
Old Oct 17, 2023 | 02:34 PM
Xjr2005's Avatar
Default trickle charger connection points in engine bay?
I would like to run a wire under the engine and make a connection there instead of at trunk any ideas ?
Do jags have a positive terminal up front?
thank you
Old Oct 18, 2023 | 09:09 AM
ChrisMills's Avatar
There's permanent battery+ at either end of fuse F35 in the front fuse box.
Old Oct 19, 2023 | 07:28 PM
Boomer from Boston's Avatar
And if your battery goes dead, this is where you can connect, to provide 12v to open the boot (trunk).
Old Oct 22, 2023 | 02:34 PM
Pete M's Avatar
Hi Boomer,
Why not use your ignition key in the slot in the boot to open it? Even the x358 has this (it's visible looking up underneath the chrome strip).
Pete M
Old Oct 23, 2023 | 08:52 AM
wfooshee's Avatar
Originally Posted by Pete M
Hi Boomer,
Pete M
He wasn't asking how to open the trunk, he was asking where he can connect a battery maintainer other than at the battery itself.
That fuse box location will take a maintainer, but it wouldn't be sufficient for jump-starting the car!
Old Oct 23, 2023 | 01:24 PM
ChrisMills's Avatar
I don't see why trickle charging at the front is easier than the trunk. I just put a thin wire out the trunk.
Some have had difficulty with the key trunk release, I guess because it's never used. I "exercised" mine and it was indeed difficult though worked eventually.
Old Oct 23, 2023 | 01:41 PM
wfooshee's Avatar
It might not be a permanent connection they want, but something they can put on the car after it sits a few days. Opening the hood and finding that point is a lot easier than digging out the battery, especially if you're not very tidy about what you carry around in the trunk all the time.
Pete M's Avatar
Hi wfooshee
Yes, I saw that, but Boomer from Boston piped up about using the power so he could open the trunk. I just wanted to let him know there is a keyhole, it's just not obvious.
Pete M
Old Oct 23, 2023 | 02:20 PM
wfooshee's Avatar
I completely missed the "Hi, Boomer" in your post!
Old Oct 23, 2023 | 02:31 PM
ChrisMills's Avatar
Dig what battery out?
Old Oct 23, 2023 | 02:45 PM
wfooshee's Avatar
Like I said, he may not be looking for a permanent connection. I've hooked mine up all of two times in the three years I've had the car, just using the clamps on the battery posts. But I keep my trunk clean and empty.
Yes, you can use a permanent pigtail and just connect the maintainer as needed, but I have a couple motorcycles and all of my pigtails are in use elsewhere.
lordpeterk
May 29, 2023 12:26 PM
66RBS
Oct 17, 2022 10:15 PM
Scheffi
Aug 25, 2020 03:54 AM
nasomi
Dec 3, 2016 11:36 AM
RCG
Oct 6, 2013 08:13 PM
