trunk/boot pull down/releaese works when key or cars button is pressed,but....
Old Aug 8, 2011 | 05:29 PM
prelude4ws's Avatar
Default trunk/boot pull down/releaese works when key or cars button is pressed,but....
My trunk will only open when i use the key manually. When i use the remote(button on key or in car) the trunk tries to open, the pull down motor operates and trunk opens or closes but only about 3/4 of an inch(seems like the latch is not releasing). I imagine it is an alignment issue but not sure, any ideas or suggestions? car is a 2004 xjr and the problem started out intermittently but now is all the time.
Old Aug 9, 2011 | 03:28 AM
peterjameswass's Avatar
Hi there.
Had a similar problem on my X-Type and also my current XJ6. The cure for me was to adjust the two rubber 'springs' which are attached to the underside of the boot (trunk) lid. They can be turned to either make them protrude more or less from the boot lid so try giving them a half turn anti-clockwise - this will hopefully make the boot lid pop up further when you unlock it, freeing it from the catch. If not, try another quarter turn at a time until it works.
Good luck!
Peter
Old Aug 9, 2011 | 06:59 PM
V7Goose's Avatar
Cool Sounds normal
Never mind - I did not notice your comment that the latch was not releasing.
Old Aug 10, 2011 | 08:38 AM
Fraser Mitchell's Avatar
I had a problem with bootlid release. It got worse and worse, until eventually when I had to lift the lid whilst pressing the release button, and then hold the lid open, that I realised what the fault was. It was obvious that one of the gas struts had failed. New gas struts solved my problem at least. There was noticeable oil seepage from one strut, the other appeared OK, but I replaced the pair so I got a two year warranty from the supplier. They are non-Jaguar struts and cost £15 each.
Old Aug 10, 2011 | 02:54 PM
prelude4ws's Avatar
i will check these suggestions this weekend and follow up on sunday or monday.
Old Aug 15, 2011 | 12:21 PM
jagfan's Avatar
Default Trunk release
I have a 2007 XJ that exhibited the same problem. The trunk would open a fraction of an inch but all the pulling in the world would not get it to open fully. I got worse and worse until I had to have the electronic trunk release replaced. Has worked fine ever since.
Old Aug 15, 2011 | 06:40 PM
prelude4ws's Avatar
i tried the suggestions and no-go.Thanks again, peterjameswass and fraser mitchell. jagfan i think you are right, that the problem lies in the electronic trunk release assembly, before i buy the whole assembly i will remove it and see if i can repair, rebuild, or replace the broken or worn part. from what i saw on sunday it seems to be riveted/stamped together,however, i did not remove it completely. i will try remove it later this week. and post what i find.
Old Aug 20, 2011 | 12:54 PM
rick1965's Avatar
had same problem on 2006 xj . at first happened occasionaly . did not happen when i brought into dealer several times. then finally it would only open with key. the trunk release mechanism had to be replaceed. several hundred dollar. of course it only stopped working completely after my warrenty had expired.
Old Aug 20, 2011 | 02:52 PM
Brutal's Avatar
Replace the latch, common issue
BrentGardner
29
Dec 16, 2024 12:13 AM
johnnie ryall
Oct 19, 2015 09:44 PM
Ziggybeben
Aug 30, 2015 02:09 PM
Bcrary3
Aug 28, 2015 10:13 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
