trunk lid closing motor
Old Dec 13, 2021 | 06:25 PM
MaxTorq's Avatar
Default trunk lid closing motor
hello gents,
i am on to my next prospective candidate for purchase...it's a 2004 XJR-"S" (silver paint/ black interior) out of california with 82K...that has a few odd notes to pick your experienced brains (thank you!) so as not to get someone else's refuge/ problem child.
the trunk will only open with the key.. none of the fob/ interior release/ trunk button will actuate the release/open the trunk so i am thinking the motor ? where the heck do i find one of those..?..
as well...for some reason there has been red welting/trim added to all the seat bottoms...huh..?...
that will have to go back to original.
your input is GREATLY appreciated,
max
Old Dec 13, 2021 | 06:36 PM
Fraser Mitchell's Avatar
It could be a broken wire in the loom that goes into the trunk lid. Every time you open the lid this loom gets a twist. If the loom is not positioned correctly then wires can snap after a while. Before you whack-out on new parts, best check the connections where they connect to the lock and motor.
Old Dec 14, 2021 | 10:44 AM
wfooshee's Avatar
None of the switches actually go directly to the motors involved in these cars. The switches are inputs to control modules. By pressing a button, your are "requesting" that a certain action be performed. The electronics decide if conditions make that action allowable. For example,m the trunk release button doesn't work if the car is in gear and moving, or maybe just in gear (I'm not sure.) So you can see that suddenly, your list of things to look for just got a lot bigger. That control module has numerous inputs that have to be satisfied before it will trigger the release motor.
That said, it could be a fuse, a broken wire, a bad motor assembly, or whatever. You'll need to find the wiring diagram and track down the signals, or find someone who can. It's not just a switch and a motor in these cars; everything is electronically monitored and permitted.
Old Dec 14, 2021 | 04:51 PM
Even opening the glove box is a "request" !! Yes, it's a bit barmy
Old Dec 16, 2021 | 02:05 PM
DutchSuper350's Avatar
I had the same issue and replaced the motor last week. Easy job (about 20 minutes) but the part is expensive. It was about EUR 315,- ex shipping
Old Dec 17, 2021 | 09:23 AM
wfooshee's Avatar
An expensive thing to try if you're not actually sure it's the motor. Buy one that has a return policy...
Old Dec 17, 2021 | 12:55 PM
Wingrider's Avatar
No returns on electrical components, is very often the venders policy.
Awfully easy to switch many bad electrical components, then return them.
Old Dec 17, 2021 | 01:08 PM
it was a no brainer. Lock already started to make noise in the weeks before it completely stopped reacting to either button (key/dash).
Trunk motors often ‘die’. Did not even consider buying a used part.
fredpribyl
XF (X260)
Dec 21, 2020 06:34 AM
Aldo M Martinez
Apr 6, 2020 06:20 PM
lzarc1
Dec 28, 2016 12:50 PM
wyxtype
Aug 4, 2014 04:16 PM
Angel Tsvetkov
Oct 23, 2013 11:11 AM
