Trunk not seating - doors unable to be locked
Old Oct 10, 2008 | 07:19 PM
christo's Avatar
Default RE: Trunk not seating - doors unable to be locked
Hey Ann welcome to the forum. I am not to familiar with your vehicle but if I recall my Lincoln had the same problem. I found the the motor in the lock has gone south and needed replacement. I am hoping there is an easy fix and this is just something characteristic to the vehicle that is not serious. "IF" it does need replacement there should just be a couple screws and a wire, I would imagine getting the beauty cover off the inside of the trunk would be the hard part. Good Luck!
Some else should be around shortly that might know better.
Old Oct 11, 2008 | 07:04 AM
christo's Avatar
I believe the motor and the mechanism are 1 piece.
Old Oct 12, 2008 | 03:15 PM
oldmots's Avatar
Just as a reminder, it's a good idea to check fuses and relays before opening things up, it could save some time.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
GordoCatCar
Jan 2, 2017 01:10 PM
XJsc-guy
Nov 23, 2015 01:56 PM
