using the J gate shifter
Old Sep 30, 2010 | 12:37 AM
haggis95's Avatar
Default using the J gate shifter
Does anyone here actually use the left hand side of the J gate shifter?
Having driven manual/standard/stick most of my life I feel the need to get engaged with the gears. I really miss having a clutch! However, every now and then I shift the gears myself - especially if sat next to a beemer at the traffic light!
One question I have -how come there is no first gear? And does the car go through first to get to second when shifting "manually?" I tend to think it does.
Also, are there any advantages or disadvantages to "shifting manually" that those more wise than me in jag lore might know?
Old Sep 30, 2010 | 01:59 PM
Fraser Mitchell's Avatar
I have found shifting manually using the J gate for rapid overtaking is better all round, because you can pre-select a low gear before commencing the overtake, whereas if you rely on the box control, there is always a pause after you have pressed on the gas pedal until it decides what gear it is going to allow you to use, so yes, there is benefit.
Of course on our twisty and narrow English roads there is never a great deal of road space for overtaking, so one has to make maximum use of what is available and move quickly.
Old Oct 2, 2010 | 01:43 AM
MarlboroLTS's Avatar
Quick downshift for passing, and downshift for help with braking suddenly. Once I got used to it, now I used it all the time.
Old Oct 3, 2010 | 01:27 PM
JagMaster's Avatar
i use it all the time to slow down and speed up
Old Oct 3, 2010 | 01:58 PM
haggis95's Avatar
Cool - so it's not just me!
I also find in slow, crawling traffic that I use less gas if I stay in 2nd rather than let the transmission hunt for the right gear all the time.
Old Oct 3, 2010 | 04:13 PM
Hey, that's a new one on me. I'll give it a try !
Old Oct 3, 2010 | 04:55 PM
GorillaArms's Avatar
I often use it Dallas traffic to force a quick downshift and hard acceleration
Old Oct 4, 2010 | 05:43 AM
Always. ^
I use the selector for overtaking, if I need to do so, quickly.
I suspect the down side of using it as you would a manual geared car, is more wear in the gear box and engine, by not driving at revs optimized by the computers.
Of course I have no data to back up my suspicion.
Old Oct 4, 2010 | 08:21 AM
Mikey's Avatar
The J selector simply limits the highest gear that the transmission can select. It does not force the transmission to stay in the selected gear continuously.
Old Oct 4, 2010 | 09:17 AM
haggis95's Avatar
Thanks Mikey - that makes sense.
n2audio
19
Jan 20, 2025 09:35 PM
adam699
Oct 13, 2015 05:53 PM
Johnken
Oct 2, 2015 10:12 AM
Johnken
Oct 1, 2015 05:07 PM
